Defrost not working properly
Old Nov 26, 2003 | 03:29 PM
Elisa's Avatar
Default Defrost not working properly
Our daughter's Standard transmission 1992 Integra RS' defrost system doesn't seem to work properly. Any suggestions? Thanks.
Old Nov 26, 2003 | 03:47 PM
:jdmshmaydm:'s Avatar
Default Re: Defrost not working properly (Elisa)
Have you checked the fuses? That could be it.
Old Nov 26, 2003 | 04:00 PM
Elisa's Avatar
Default Re: Defrost not working properly (Gatecrasher20AF)
Dear Gatecrasher:
The defrost fan works. There seems to be moisture in the air and it doesn't allow the window to defrost properly.
Old Nov 26, 2003 | 04:09 PM
fivespeedintegra's Avatar
turn on the a/c when you turn on the defrost as well. that will get rid of the moisture.
Old Nov 26, 2003 | 05:50 PM
Regular Series's Avatar
Default Re: Defrost not working properly (fivespeedintegra)
Yeah, Integras are a little strange that way. Most cars turn on the A/C automatically with the defroster; Tegs don't.
Hit recirculate if you want the moisture to go away quickly. If you still have problems, the A/C system may need a recharge or repair.
Old Nov 26, 2003 | 06:27 PM
roadrunner's Avatar
Is this a problem with defrosting or defogging?
Old Nov 27, 2003 | 05:33 AM
Elisa's Avatar
Default Re: (roadrunner)
It hasn't been cold enough yet to use as the defroster but on cool, rainy days the defogging won't work. The fan works and we have cleaned it out but it is has moisture.
Old Nov 27, 2003 | 06:01 AM
that is because you must turn the A/C on as well in order to get rid of the moisture.
Old Nov 27, 2003 | 10:22 AM
Elisa's Avatar
Default Re: (fivespeedintegra)
Thanks. Will this work even if the A/C isn't working properly?
Old Nov 27, 2003 | 10:46 AM
Default Re: (Elisa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elisa &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. Will this work even if the A/C isn't working properly?</TD></TR></TABLE>
no. a/c removes moisture. you'll need to get that fixed too.
teg_racer
Jun 2, 2011 04:56 PM
Keno20
Nov 24, 2004 08:34 PM
servion
Oct 23, 2003 08:02 AM
