rotating turbo housing and oil lines
Old Nov 26, 2003 | 02:32 PM
quick1racer's Avatar
Default rotating turbo housing and oil lines
i have t3 t4 turbonetics
i rotated the housing so the charged outlet pipe wouldn't hit my radiator
it now faces down
i also rotated the oil lines so instead of being vertical -----
they are now at a 45 degree angle to let the lines clear the block
will this effect reliability or performance in any way
my first turbo install need some help
Old Nov 26, 2003 | 05:06 PM
ross1459's Avatar
Default Re: rotating turbo housing and oil lines (quick1racer)
you may have drain problems. oil inlet and outlet should be as close to vertical as possible
killamike0001
Sep 8, 2007 09:17 AM
Slammd Sol
Nov 7, 2004 10:00 AM
JrCRXHF
Aug 26, 2003 07:11 AM
B18C-RnVA
Jun 28, 2002 05:47 PM
