How do you know....
Old Sep 14, 2001 | 10:57 PM
d0nkeyxPunch's Avatar
Banned
Default How do you know....
This might be a very dumb question but how do you know if you need to change your car battery? Last night as I was going home, the e-brake light came on while my car was on the freeway. When I started my car today, it worked fine until I started to go. The rpm just dropped and my e-brake light came on. Then my engine stalled. The battery light came on as well as the e-brake. Does this mean I need a new battery??? Please help me because I need to get to work. Thanks.
Old Sep 15, 2001 | 12:13 AM
FaTBastarDinaCiviC's Avatar
New User
Default Re: How do you know.... (FastxCivic)
Try charging your battery, if it happens again have your alternator checked.
Old Sep 15, 2001 | 04:53 PM
BreakStuff's Avatar
New User
The battery light, among other indicators will come on whenever the car stalls, this does not necesarilly means theres a problem with the battery..
Is your car a manual transmission?
Do you apply the e-brake when you park the car?
Does the E-brake feel tight when you lift up the handle or does it feel sloppy with alot of play?
What I am leading to is maybe the fact that your E-brake cables are frozen and when you are driving the car, the emergency brake is actually applying pressure causing a load on the motor/transmission and making the car stall..
Old Sep 16, 2001 | 12:13 AM
Banned
Default Re: How do you know.... (BreakStuff)
Yeah, my car is manual transmission and I ALWAYS pull up my E-brake whenever i park. The e-brake doesn't really tight or weird. Just feels semi soft. I don't know. Its just normal I guess. The thing is I am running my stock B16A ecu. My car is running lean with the stock ecu because of the modifications. I drove the car normally for the past 3 weeks or so. Nothing really happened. Until like 3 days ago this started happening. So I tried my old Mugen Ecu which made my car run rich. The car worked fine. Didn't stall or anything. I AM REALLY CONFUSED!
Old Sep 16, 2001 | 04:09 PM
88_SC_CRX_Si's Avatar
New User
When was the last time you checked you brake fluid, and have your brakes changed any?
Old Sep 16, 2001 | 08:01 PM
91LUDESI's Avatar
New User
Default Re: How do you know.... (88_SC_CRX_Si)
its your alternator i had the same problem your car starts to bog out right. i changed my alternator and it went away. check your alternator belt
M3THTICAL(EF)
May 4, 2015 06:05 PM
Spence
Dec 11, 2006 02:27 PM
uneek4dr
Mar 26, 2006 11:24 AM
srswarts3
Aug 6, 2005 03:47 PM
JMX
May 25, 2005 06:39 AM
