Damn connecting pipe is leaking....HELP
Old Nov 26, 2003 | 09:39 AM
IloveNewt's Avatar
Default Damn connecting pipe is leaking....HELP
Well i come home for Thanksgiving break and look at the garage floor and what do i see......it covered in coolant.
I look underneath and its drippin like a drop a second. Upon further investigation it is comin from the connecting pipe behind the block and the water pump. Ther water pump was replaced so i think its just the o-rings between the water pump and the connector pipe that must be bad.
Im tryin to see if i can get the connector pipe off with the engine in the car.....any tips on how to get it off easy?
Old Nov 26, 2003 | 10:14 AM
PrecisionH23a's Avatar
Default Re: Damn connecting pipe is leaking....HELP (MordecaiPSI)
You can replace the 0-ring without yanking the motor but its a bit of work. First you need to drain the coolant of course, then remove any brackets in the way. I believe the IM bracket is in the way and if you need to change your oil now is the time since removing the filter will give you more space to work. If you need a sheet from the honda manual with the whole process let me know and ill email it to you.
Old Nov 26, 2003 | 12:39 PM
IloveNewt's Avatar
Default Re: Damn connecting pipe is leaking....HELP (GudeH23a)
thanks...IM'ed
Old Nov 26, 2003 | 03:12 PM
99spanishGT
Guest
Posts: n/a
Old Nov 26, 2003 | 10:08 PM
IloveNewt's Avatar
Default Re: Damn connecting pipe is leaking....HELP (spanishlude)
Do you want to give me any tips on how to do this?
Jagan'92
Apr 2, 2019 07:01 AM
Ej8 d16
Mar 21, 2018 06:00 PM
Ainsworth03
Honda Civic (2006 - 2015)
Jun 27, 2014 12:56 AM
shilly
Oct 7, 2008 02:42 PM
GalDemSuga
Jan 15, 2007 05:54 AM
