obd1 to obd2 question
Old Nov 25, 2003 | 07:05 PM
rice4life's Avatar
Default obd1 to obd2 question
i wanna run a 98 jdm type R ecu in my 94 cx. other than the conversion harness, what else do i need to do. do i need to run the second o2 sensor or don't i need it.
Old Nov 25, 2003 | 09:25 PM
turkdog's Avatar
Default Re: obd1 to obd2 question (rice4life)
Im running a p73 ecu myself(jdm itr ecu). however I also have the motor. I ecu is obd2 but ecu works like an obd-1 ecu and using the the sensor on the exhaust manifold near the end where the collector is. Just us the jumper harness and you'll be fine if everything is ok now. The jdm itr ecu basically works just like the p28. It only looks for one o2 sensor!!
Old Nov 25, 2003 | 09:45 PM
rice4life's Avatar
Default Re: obd1 to obd2 question (turkdog)
i also have a jdm type R engine. are you using 2 O2 sensor or just one?
Old Nov 26, 2003 | 10:34 AM
Jaker's Avatar
If its really a JDM ITR ECU, you won't need any of the extra USDM OBD2 sensors. Stuff like the 2nd O2 sensor, crank fluctuation sensor, and fuel tank pressure sensor are not needed with a JDM ECU.
duf2570
Apr 23, 2014 08:20 AM
rice4life
Nov 30, 2003 07:29 AM
sneakychaos
Nov 22, 2002 12:30 PM
