ZC hybrid tranny with Si final drive, want to change 5th gear....
Old Nov 25, 2003 | 06:09 PM
b17gsr's Avatar
Default ZC hybrid tranny with Si final drive, want to change 5th gear....
Ok, a buddy of mine has a 88 CRX Si. We installed a ZC motor and tranny. The guy that sold us the swap installed a Si final drive. Makes for fun acceleration, but 5th gear is useless on his long commutes on the highway.
I'm thinking of installing the 5th gear from either a Si or DX. Will the 5th gear from either fit on the ZC shafts?
TIA
Old Nov 25, 2003 | 06:34 PM
onePOINTsix's Avatar
Default Re: ZC hybrid tranny with Si final drive, want to change 5th gear.... (b17gsr)
yes! use the 5th from the Si tranny, the ZC one only drops about 600rpm between 4th and 5th
Old Nov 25, 2003 | 06:54 PM
davens's Avatar
In 5th at 80mph...
Si/DX will put you at 3900
The Hf 5th will put you around 3500
edit: 100 rpm correction
Modified by davens at 8:21 AM 11/26/2003
Old Nov 25, 2003 | 06:59 PM
b17gsr's Avatar
I like the RPM with the HF gearing.
Old Nov 25, 2003 | 11:14 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (b17gsr)
go with the Si/DX .771 5th. The ZC needs the revs to make the power.
Old Nov 26, 2003 | 12:09 AM
CRX-RX's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">go with the Si/DX .771 5th. The ZC needs the revs to make the power.</TD></TR></TABLE>
For sure Very happy with my ZC fifth on three hour drives. But keep in mind it's mid range power. The DOHC ZC's get almost violent above 6,500 or so.
Old Nov 26, 2003 | 12:28 AM
^jefs0ng's Avatar
Banned
I just got my ls 5th gear for my b16 I'm so excited to see my revs ~1500 rpms lower than normal at 80!
Old Nov 26, 2003 | 04:06 AM
virginia_dude's Avatar
DO the Si 5th, low enough to help but high enough to keep you near the power band.
Old Nov 26, 2003 | 04:21 AM
VelocityR's Avatar
Default Re: (CRX-RX)
What RPM at 80 mph with ZC tranny. My ZC tranny is being installed in 2 weeks.
Old Nov 26, 2003 | 05:03 AM
keithv's Avatar
Default Re: (VelocityR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VelocityR &raquo;</TD></TR><TR><TD CLASS="quote">What RPM at 80 mph with ZC tranny. My ZC tranny is being installed in 2 weeks.</TD></TR></TABLE>
A ZC tranny without the Si final drive is pretty low. I forget exactly how low and I don't have the numbers here.
Old Nov 26, 2003 | 05:05 AM
Default Re: (keithv)
at 80 I am taching just over 4,000 RPM And thats not a hybrid tranny.
Old Nov 26, 2003 | 05:23 AM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">
A ZC tranny without the Si final drive is pretty low. I forget exactly how low and I don't have the numbers here.</TD></TR></TABLE>
4036 rpm
Old Nov 26, 2003 | 05:25 AM
davens's Avatar
Default Re: (virginia_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">at 80 I am taching just over 4,000 RPM And thats not a hybrid tranny.</TD></TR></TABLE>
The math figure kicks out 3874 rpms
This will be off a little if you're wheels/tire diameter is different then stock. Also, stock tachs are notoriously inaccurate...a couple hundred rpms is common.
Old Nov 26, 2003 | 06:58 AM
b17gsr's Avatar
Any special tools required to swap the 5th gear? Should we use the 5th gear from the Si tranny that was in the CRX, or buy a new one?
Old Nov 26, 2003 | 10:45 AM
Default Re: (davens)
Yes, that is about right, No way would I stake my life on tack accuracy.
Old Nov 26, 2003 | 11:37 PM
Mista Bone's Avatar
D Tranny Guru
what FD are you using and what is your goals?????
70 mph and 3200-3400 rpm are that target cruising goals.
CRX Si gearbox would be at about 3500 at 70 mph.
DEFINE YOUR GOALS!!!!!!!!!
Old Nov 27, 2003 | 07:05 AM
b17gsr's Avatar
I can't believe Mista Bone missed "Si final drive" in the title.
The goal is lower revs, so the combined 2 hour daily drive on the highway isn't so buzzy and a bit easier on gas. Average speed around 120 km/h = ~75 mph.
Looks like the HF 5th gear might be the way to go.
Old Nov 27, 2003 | 01:42 PM
LoneStarCRX's Avatar
I am looking at a ZC hybrid with Si FD and HF 5th for my highway cruising. Wacky, huh? Mike at Effin Motorworks has one and says it was a huge performance boost for him while having a very nice cruising RPM. He said it feels a little strange at first going from 4th to 5th.
My only concern is that some have said I will be "out of the powerband" with the HF 5th and will actually have less MPG. It will be 80 MPH at 3487. Surely the ZC is efficient at that point.
Old Nov 27, 2003 | 07:11 PM
b17gsr's Avatar
So would I keep the ZC 5th gear synchro, or use the Si 5th gear synchro?
Anyone done this swap, any tricks? Time to read the service manual I guess.
Old Nov 28, 2003 | 01:50 AM
Mista Bone's Avatar
D Tranny Guru
the synchros are the same, use which ever looks the best.
Inspect the 1-2 shifter fork also, major wear item.
BTW....Yeah I missed the FD issue, but you know how my boards I surf daily to provide correct info?????
TOO MANY!!!!!!!!!!
Old Nov 28, 2003 | 05:19 AM
Giuseppe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">the synchros are the same, use which ever looks the best.
TOO MANY!!!!!!!!!!</TD></TR></TABLE>
Bone is the D series Tranny guru.!!!!
(period)
trooper0641
17
Feb 5, 2017 08:49 PM
2kTeg
Oct 21, 2005 10:04 AM
B18C5-EH2
44
Jul 6, 2004 04:54 PM
BseriesHatch
Jun 3, 2003 09:39 PM
GirlyGS-R
Feb 20, 2003 09:06 PM
