Sedan exhaust on a hatch?
Old Nov 25, 2003 | 06:08 PM
Louie B.'s Avatar
Default Sedan exhaust on a hatch?
I found plenty of topics about putting a hatch exhaust on a CRX, but nothing on putting a 4-door exhaust on a hatch.
Has anyone tried putting a cat-back that was originally designed for a 88-91 4-door onto a 91 hatch? if so, how much pipe and from where will I need to cut off, if any?
Old Nov 26, 2003 | 06:29 AM
dingusjt's Avatar
Default Re: Sedan exhaust on a hatch? (thumpu77)
honestly its no more that about 2 ft of pipe if that and you can chop right from the middle would be easiest cause if i'm not mistaken the axle-back exhaust section is almost identical...
hmmm that reminds me..i'm selling my complete 88-91 Sedan 4 door exhaust..check it out!!
https://honda-tech.com/zerothread?id=680257
Old Nov 26, 2003 | 09:43 AM
Losrocket_'s Avatar
Default Re: Sedan exhaust on a hatch? (dingusjt)
The axle back section is the same as HB's other than the piping outlet i.e. the pipe from the muffler to the tip. That will be too long but you can cut it down and reweld the tip. Im unsure about the section from the cat to the axle.
Old Dec 5, 2003 | 10:27 PM
Louie B.'s Avatar
Thanks for the replies guys.
In case someone finds this post in a search later on, here's what I came up with....
The Intermediate is identical between the hatch and sedan, as is the axle-back except the length of the tail pipe.
"It just sticks out a little"
Accually, I'm not a big tip fan anyway. My plan is to just hack the pipes off and put some regular tips over the end.
Ahh, the famous ST swaybar issue! Only I always heard that it was the "over the axle" pipe that had clearance problems... my problem is that the muffler itself is too wide and hits the bar. Once the car is set on the ground, it's not as bad, but it still rubs. My solution is to put some spacers in between the intermediate pipe and the axle-back and then re-mount the hangars on the axle-back. this will move the whole works back which will mean I'll need to hack even more length off of the tips.
In case anyone's wondering, this system is the Brosal "Brospeed" cat-back system. The pipes are 2" mandrel bend. Not the 2 1/4 that I was hoping for, but at $189.95 shipped for the whole system brand new, I figured it's better than what was on there!
Old Dec 6, 2003 | 08:48 PM
MestizoRacer310's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">
"It just sticks out a little"</TD></TR></TABLE>
So what you're saying is that the bends are in the same places, except the pipe AFTER the muffler?
Old Dec 6, 2003 | 10:10 PM
Louie B.'s Avatar
Default Re: Sedan exhaust on a hatch? (MestizoRacer310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">
So what you're saying is that the bends are in the same places, except the pipe AFTER the muffler?</TD></TR></TABLE>
Yep.
The bends are in the right places after the muffler too, it's just the length after the bends is too long.
Old Dec 6, 2003 | 10:29 PM
Same length and bends but the exit pipes?? Sorry if I'm pestering you about it..
Old Dec 7, 2003 | 07:11 AM
b16_madman's Avatar
look at the pics man. the tips stick out past the bumper, therefor the piping after the muffler extends too far back.
Old Dec 7, 2003 | 07:50 AM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">Same length and bends but the exit pipes?? Sorry if I'm pestering you about it..</TD></TR></TABLE>
yes, the pic you see is with the exhaust all bolted in w/ no modifications. Even the hangers line up perfectly.
Old Dec 7, 2003 | 10:50 AM
Limited S.L.I.P.'s Avatar
my friend bought a 91 si hatch with a 91 ex sedan exhaust, only about 2" too long.. both exhausts were stock.
Old Dec 7, 2003 | 02:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">In case anyone's wondering, this system is the Brosal "Brospeed" cat-back system. The pipes are 2" mandrel bend. Not the 2 1/4 that I was hoping for, but at $189.95 shipped for the whole system brand new, I figured it's better than what was on there!</TD></TR></TABLE>
What's stock piping??
Old Dec 7, 2003 | 04:27 PM
dingusjt's Avatar
ok what are the differences between HB and CRX?? cause if all bolts up between different models that helps us sedan owners out alot!!
Old Dec 7, 2003 | 09:37 PM
Louie B.'s Avatar
What's stock piping??</TD></TR></TABLE>
1 3/4" crush bends
Old Dec 7, 2003 | 09:40 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt &raquo;</TD></TR><TR><TD CLASS="quote">ok what are the differences between HB and CRX?? cause if all bolts up between different models that helps us sedan owners out alot!!</TD></TR></TABLE>
according to other threads on this site, the CRX axle back is the same as the hatch and the mid-pipe is apx 7" shorter on the rex.
Old Dec 8, 2003 | 01:15 AM
KTeller8's Avatar
according to other threads on this site, the CRX axle back is the same as the hatch and the mid-pipe is apx 7" shorter on the rex.</TD></TR></TABLE>
i will agree, that the 88-91 crx and civic hatback follow the same bends and systems.. minor cutting will be needed, like mentioned.. maybe a few inches
Old Dec 8, 2003 | 04:47 AM
ijjz's Avatar
Default Re: Sedan exhaust on a hatch? (KTeller8)
Where did you get that new exhaust, the black one..?
Old Dec 8, 2003 | 05:53 AM
Louie B.'s Avatar
Default Re: Sedan exhaust on a hatch? (ijjz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ijjz &raquo;</TD></TR><TR><TD CLASS="quote">Where did you get that new exhaust, the black one..?</TD></TR></TABLE>
Ebay... It was some shop's display model, so it was a "one only" sort of thing.
Old Dec 8, 2003 | 10:08 AM
xci_ed6's Avatar
Fitting the HB midpipe on a CRX takes alot of work, the bends and resonator are in the wrong place, I'll try to get a pic.
Old Dec 8, 2003 | 10:11 AM
KTeller8's Avatar
also remember that on the sedan and civics.. the stock muffler actually has an inlet up and on the top, while the crx and hatchback is more in hte middle.. so this puts a nasty tilt on it, if you dont know how to adjust and cut it right..
Jdm305
Apr 6, 2009 03:59 PM
broketuner-Sol_Si
Oct 3, 2008 09:19 PM
jdmefhondachassis
Jun 15, 2004 08:54 PM
brucehb
Nov 20, 2003 06:03 AM
zdr262
Sep 10, 2003 07:45 PM
