LSD question
Old Nov 25, 2003 | 03:43 PM
hybridhatch18's Avatar
Default LSD question
if i jack up the car and only one tire spins do i have lsd? it was in neutral.
Old Nov 25, 2003 | 03:47 PM
Default Re: LSD question (hybridhatch18)
bump
Old Nov 25, 2003 | 03:52 PM
nightrider's Avatar
is it stamped LSD?
edit: also, there aren't any bumps in here, but why bump in a matter of five minutes?
Old Nov 25, 2003 | 04:16 PM
i've heard the stamp could have been washed off, any one else?
Old Nov 25, 2003 | 04:28 PM
Bbasso's Avatar
Washed off, mmm I have scrubed my engine clean a few times and it never came off.
As for the spinning, both of mine spin when in the air.
Old Nov 25, 2003 | 05:31 PM
was your car on when you did this?
Old Nov 25, 2003 | 06:18 PM
nightrider's Avatar
to check if your LSD is working properly , raise your car up and put in first gear. rotate one wheel and the wheel on the other side should be turning in the opposite direction. however, this does not determine whether or not you have a LSD. i got that information from a LSD thread that i found in the search. there is information as to how to check if you have a LSD, which i don't clearly understand so here's the link.
https://honda-tech.com/zerothread?id=354215
ps: the pictures don't work so i can't tell.
please_hop_off
Dec 20, 2009 04:11 AM
stock99si
May 13, 2007 03:44 PM
HondaPH22
Nov 23, 2006 12:52 AM
ek4ferrio
Sep 12, 2006 08:24 PM
carblegal
Dec 22, 2005 06:33 PM
