anybody use a mitsu starion turbo?
Old Nov 25, 2003 | 02:05 PM
B_1_8_hatch's Avatar
Default anybody use a mitsu starion turbo?
i found one for sale for a good price, but what do you people think about that turbo?
Old Nov 25, 2003 | 06:21 PM
Default Re: anybody use a mitsu starion turbo? (93hb)
anyone know how good this turbo is?
Old Nov 25, 2003 | 09:02 PM
SiR Kid's Avatar
New User
As far as I know it's a TD05 16g...
It's a great turbo for a D series, or a VERY peppy feeling B series turbo setup.
FYI, it's VERY similar to the turbo on the new Mitsu Evo VIII's.
Old Nov 25, 2003 | 09:46 PM
out there's Avatar
Default Re: anybody use a mitsu starion turbo? (SiR Kid)
according to a turbo dedicated site, the turbo from a starion is a tc06, probably similar to a td05. i think it's pretty close in flow to a 16g. you'd be better off with a big16 or t28. unless you want some serious power, then a 57trim, 60-1... check out http://www.slowboyracing.com or www. agpturbo.com
Old Nov 25, 2003 | 10:00 PM
Default Re: anybody use a mitsu starion turbo? (out there)
wouldn't it be a better turbo than the small td04 greddy turbo that i'm using now?
Old Nov 26, 2003 | 10:15 PM
out there's Avatar
it would be marginally better; depends on how much you can get it for. i found a big16 over http://www.thepartstrader.com for 150 (though the bearings were worn) and a small16 for 175 (about 1400miles on it). shop around a bit, look on http://www.dsmtrader.com too, there are often t28s on there for a pretty decent price
Old Nov 26, 2003 | 10:25 PM
kpt4321's Avatar
16g's for under 200 dollars are probably junk. Good, even decent ones go for 300-500.
The small 16g and the big16g are VERY CLOSE to being the exact same turbo, in fact, the small 16g is going to be more efficient at boost levels less than 25ish psi. That means that you guys should stick with the small.
Also, the small is NOT too small for a turbo Honda!! It can make well over 330 whp, making it much better that most kits come with.
Without any more information about the Starion turbo, I don't want to comment and be wrong.
andysila
Jan 29, 2005 12:37 PM
4_door_teg
Dec 7, 2004 10:30 AM
4potnick
Aug 23, 2002 08:43 AM
