Anyone have troubles with VSS?
WEll im trying to get my mechanical vss outta my si tranny to replace it with an electric one so i can run my jdm cluster. and im having a bitch of a time getting the mechainical one out.
Ive tried just bout eveythign i could think of and i dont really want to break it off, cause that happened to me before and wasnt very good.
Anyone have any good ideas, tips to get the old one out?
the tranny is outta the car btw
grab it with some chanell locks and twist it side to side and it should break loose then you can twist it some more and pull up on it.
From: 9/11/01 WTC Never Forget, United States Of America
I couldnt get mines out either had a GSR cluster in my hatch but the speedo didnt work so now i have a 92 GS cluster in my hatch with the cable vss looks better
yeah i tried vice grips with twisting...just stripped it and it was hella tight. Then i tried putting a wedge under the vice grips and use the vice grips to hold the sensor while i pryed down on the other side and still nothing! i really want to use my jdm cluster!! any more help?
tighten them down more
tight as you can get em! and twist that bitch loose. It always worked for me. Also could try soaking some liquid wench or WD around it too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giuseppe »</TD></TR><TR><TD CLASS="quote">any of you guys unclip the damn thing b4 yanking it out of the tranny.??
The clip holds the throttle cable in. A bolt/bracket hold the VSS in
</TD></TR></TABLE>The clip holds the throttle cable in. A bolt/bracket hold the VSS in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 »</TD></TR><TR><TD CLASS="quote">
The clip holds the throttle cable in. </TD></TR></TABLE>
my bad,
but your bad for saying throttle cable instead of vss cable...
my bad,
B20zvtecek
Nov 20, 2002 06:30 AM
