Code 9 on obd0 1991 crx si.....
Old Nov 25, 2003 | 01:23 PM
Sirex's Avatar
Default Code 9 on obd0 1991 crx si.....
Got a code 9......
i guess i need a new dizzy?
anyway to fix it?
Old Nov 25, 2003 | 01:38 PM
bryant's Avatar
Default Re: Code 9 on obd0 1991 crx si..... (Sirex)
You answered your own question.
Old Nov 25, 2003 | 01:46 PM
USDM 4G VTEC's Avatar
if u did MPFI swap make sure u used shielded wire and that the wires arent inverted
as on my case i have used 3 known good dizzys and i still get the code, i got shieldede wire, i hazve all soldered and have checked my wiring 10 times and still got the code.. doesnt affect my performance at all...
Old Dec 8, 2003 | 01:19 PM
Sirex's Avatar
Default Re: Code 9 on obd0 1991 crx si..... (USDM 4G VTEC)
nope i have a 1991 crx si..
Old Dec 8, 2003 | 01:35 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
http://www.binghamtonlife.com/...s.htm
see: 11-52 and 11-53...
Old Dec 8, 2003 | 07:05 PM
Sirex's Avatar
Default Re: Code 9 on obd0 1991 crx si..... (88DXCRX)
i got that manual :D
Old Dec 8, 2003 | 09:26 PM
[626]95-GSR's Avatar
ive replaced my distributor 5 different times and i still end up with this damn code..
If anyone has anything to offer for a solution, please give your input. Im positive its somewhere in the wiring harness if replacing your distributor does not solve your remedy. Otherwise, yes the problem lies within the distributor housing where the crank sensor is located.
mike9571
Jul 9, 2007 09:05 AM
rustbucketrex
Jun 28, 2007 06:43 AM
mightymaxgst
Nov 27, 2006 10:28 AM
WhiteDSM520
May 6, 2003 11:06 PM
