how to start a car without a tranny on car???
Old Nov 25, 2003 | 01:18 PM
JBBNJ609's Avatar
Default how to start a car without a tranny on car???
ok i just want to see if my car will start , no axles on tecar , no tranny , i have a starter , but its not on the car , i do have flywheel and clutch on car still is there a way to start it up???? thanks
JAY
Old Nov 25, 2003 | 04:43 PM
LSTEG96's Avatar
Default Re: how to start a car without a tranny on car??? (jason bouchard)
ROFL
Old Nov 25, 2003 | 04:48 PM
SubieDude's Avatar
i wouldn't suggest it
Old Nov 25, 2003 | 06:11 PM
Audio28's Avatar
Default Re: how to start a car without a tranny on car??? (WhiteS2)
try it and let us know.
Old Nov 25, 2003 | 06:18 PM
phuckinilltegie's Avatar
Default Re: how to start a car without a tranny on car??? (Audio28)
just curious but what is going to happen when he tries this??
Old Nov 25, 2003 | 06:52 PM
DA9RsIntegra's Avatar
Default Re: how to start a car without a tranny on car??? (phuckinilltegie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phuckinilltegie &raquo;</TD></TR><TR><TD CLASS="quote">just curious but what is going to happen when he tries this??</TD></TR></TABLE> he will open the key to Narnia! Hope he tries it
Old Nov 25, 2003 | 11:02 PM
Cyphear's Avatar
I think you'll be cool. Other than an obvious check engine light. Oh, and remember your going to squirt some clutch fluid out of the line when you press the clutch in to start it. You might want to put some more support under the motor too. Isn't there only one motor mount holding it in right now? I always used a carjack to suport my motor.
Old Nov 26, 2003 | 12:12 AM
JBBNJ609's Avatar
Default Re: how to start a car without a tranny on car??? (Cyphear)
hey you guys shouldnt flame me on thios im not some stupid noob , you can start a car without the trany i just dont know how , i have 3 motor mounts opn the car now and yes a bottle jack under , i wouldnt be pushing the clutch pedal down much( enough to squirt fluid out) cise it wouldnt make a diff in anything but triping the switch to start it . . . .
Old Nov 26, 2003 | 12:26 AM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audio28 &raquo;</TD></TR><TR><TD CLASS="quote">try it and let us know.</TD></TR></TABLE>
lovin the avatar
Old Nov 30, 2003 | 05:41 PM
GSRontheBottle's Avatar
Default Re: how to start a car without a tranny on car??? (integraL)
Dont know how, but good luck and please let me know how it goes. Thanks
Old Nov 30, 2003 | 05:49 PM
Mr. Choi's Avatar
New User
Default Re: how to start a car without a tranny on car??? (GSRontheBottle)
if im not mistaking, the stater bolts on to the tranny. so how will you turn the engine witout the starter?
umm... why do you want to do this?
Old Dec 1, 2003 | 08:13 AM
JBBNJ609's Avatar
Default Re: how to start a car without a tranny on car??? (Mr. Choi)
i dont have a tranny now and the insurence comp totaled the car , if the engine doesnt work, i will let them take it back ,but if it does work i will buy it back
Old Dec 1, 2003 | 08:35 AM
yellaboi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Choi &raquo;</TD></TR><TR><TD CLASS="quote">if im not mistaking, the stater bolts on to the tranny. so how will you turn the engine witout the starter?
umm... why do you want to do this? </TD></TR></TABLE>
the starter does bolt to tranny.
ONe of the starter bolts does go all the way through to the block. Maybe if you had a spacer of some sort the same thickness as tranny housing by starter you could bolt it in place enough to engage flywheel. Just make sure stater is tightened down.
This really isnt the safest or smartest Idea but I understand your reasoning.
What happened to the tranny?
Old Dec 1, 2003 | 09:21 AM
StyleTEG's Avatar
Default Re: how to start a car without a tranny on car??? (yellaboi)
If you can spin the flywheel you should be able to start it with your key.
It wouldn't be a good idea, but technically you could probably spin the flywheel with a socket and rachet on one of the PP bolts, and then have someone in the car cranking.
Old Dec 1, 2003 | 09:34 AM
GSR x13's Avatar
good luck..
Old Dec 1, 2003 | 10:36 AM
gsrintegra1976's Avatar
Not gonna happen without something to mount the starter to . And I would NOT try styleTeg's idea...that sounds like a great way to get hurt BAD.. IF it did start that way you will never get the socket off fast enoug . I would flip a coin heads keep it tails let them take it . Unless you have a good idea that it will run without starting it .
Old Dec 1, 2003 | 11:17 AM
JBBNJ609's Avatar
i got in a car accident , and the trann casing was cracked .. . im getting a new one , but not for alittle bit now ( b16 tranny )
Old Dec 1, 2003 | 11:34 AM
What makes you tink the engine would be bad?
Old Dec 1, 2003 | 05:34 PM
JBBNJ609's Avatar
Default Re: (gsrintegra1976)
i just wanna make sure , idk . . .
Old Dec 1, 2003 | 06:07 PM
akhom's Avatar
Default Re: (jason bouchard)
To Start it you need to get the crank spinning. You can somehow spin it from the crank pully side or by the flywheel. Leave the Key in the on position Have someone gave it 1/4 throttle, Spin the crank somehow and if you get is going fast enough it will start. But be super careful. Once it starts you will have a socket flying all over the place. If you have a breaker bar that's worst.
Old Dec 1, 2003 | 06:33 PM
DigitalPunk's Avatar
Default Re: (akhom)
The easiest way to do it I think would be to take the back wheel off of your bicycle, wrap the chain around the flywheel, and pedal REALLY fast...
OMFG
Old Dec 1, 2003 | 07:00 PM
Brian_TII's Avatar
I've actually used an electric drill to start a mo-ped kinda like this once... Basically I found the right size socket for the crank pulley and let it rip. Obviously an electric drill isn't going to be powerful enough to turn the motor over, however you might be able to rig something up... Our boat has a rope that you can wind around the flywheel and start the motor by hand. This has worked great on the boat... maybe you could get some strong rope and rig something like this up. Becareful though cause the rope MUST be released when the engine actually does start... (otherwise it could be bad... real bad)
Old Dec 1, 2003 | 07:07 PM
PHiZ's Avatar
people runs engines on stands. I'm surprised anything "new" ever gets done on this site, with 90% of posts saying "no you can't do that" Call a junkyard, maybe import auto salvage, and see if they can give you advice.
-PHiZ
Old Dec 1, 2003 | 07:47 PM
Default Re: (PHiZ)
Im not saying that it cant happen, Im just saying its the biggest ****-for-brains idea Ive heard all day. I mean, the guy doesnt even really have a good reason to do this, other than to see if the motor is ok. I dont see why he would think the motor is messed to begin with. All im saying is, it would be easier to throw a tranny in the car, see if it runs, and then take the tranny back out if you had to, rather than come up with some half-assed plan of starting it another way.
Old Dec 2, 2003 | 07:20 AM
JBBNJ609's Avatar
Default Re: (DigitalPunk)
no , i do have a good reason , think about it , i dont have the money for a tranny , the insurence comp wants the get the car , and then i will have to buy it back , if the engine doesnt work, then its not really a smart idea to buy the car back now is it
Modified by jason bouchard at 11:43 AM 12/2/2003
