k20a3 bottom end buildup
Old Nov 25, 2003 | 12:39 PM
jdmd's Avatar
Default k20a3 bottom end buildup
ok, i have done some research on this but still can't find definite answers. here's the deal: i want to build my bottom end to ITR specs so that i can put the ITR/toda head on it. it looks like my crank in my K20A3 is the same as in the K20A, aside from the micropolishing and balancing, which i would have done when i take it out. so it sounds like i will be able to keep the stock crank and i will just have to polish it and have it balanced, but i still can't find an answer on the connecting rods.
Are the connecting rods on teh K20A3 the same as the ones on the K20A? I know for a fact i need the pistons, but i would like to know if i am going to have to buy the rods as well, thank you very much for any help.
Old Nov 26, 2003 | 03:07 AM
AussieK24's Avatar
Default Re: k20a3 bottom end buildup (theblackknight)
More research needed
a2 crank has 51mm big end journals and A3 crank has 48mm
Old Nov 26, 2003 | 08:16 AM
jdmd's Avatar
ok, but i can use that in the A3 block correct? and do you know about the rods also? thank you very much for all your help.
Old Nov 26, 2003 | 09:13 AM
foot's Avatar
Default Re: (theblackknight)
If the journals are not the same, than the rods are not the same.
Old Nov 26, 2003 | 09:25 AM
fireant's Avatar
Default Re: (foot)
If you're taking it all out to do the labor and buildup, doesnt it cost less to sell it all and get an ITR block/head for the same trouble?
Old Nov 26, 2003 | 09:33 AM
edo's Avatar
edo
A3 crank = partially counterweighted, 4
A2 crank = fully counterweighted, 8
-Ron
Modified by edo at 2:11 AM 11/27/2003
Old Nov 26, 2003 | 01:27 PM
jdmd's Avatar
alright, i guess i am just going to get the ITR block. thanks for all your help.
CK_4500
10
Jun 24, 2009 06:42 AM
lunatics209
Jun 12, 2008 01:38 AM
turbotypeR@SPEC
Dec 5, 2004 03:38 AM
LudeyKrus
Nov 12, 2003 05:37 PM
