Running the p72gsr ecu in their h22a???
Just wondering if anybody run the p72 gsr ecu in their h22a,coz someone told me it has a higher fuelcut and it can take advantage of the aftermarket cams,but i am not too sure is there any different about the fuel and ignition map.By the way they are both obd2,any info will be great,THANKS.....
man screw all that.. ems and be done with it.. im still beating the **** outta myself for buying this ****** pos hondata and the 3 p72 it fried
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits »</TD></TR><TR><TD CLASS="quote">A P72 with the stock GS-R fuel and timing maps on a H22A runs dangerously lean if you use it on an H22A.
Andrew</TD></TR></TABLE>
ditto...but p72 hondata runs great here, dont know what your bad luck is.
well I was planning on chipping it and tuning with uberdata, that's why I need to know what would be a good basemap for a stock h22 to tune it from there....And I can't chip a p13 with uberdata so don't say that, let alone any other rom editor. Anyway it's just a question it doesn't seem like anyone can answer to me anyway and I'll have to just figure it out on my own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeuceDeuce »</TD></TR><TR><TD CLASS="quote">GSR Ecu's run just fine
compared to not running at all i guess you could say its fine
but otherwise, no they dont, they suck unless tuned with hondata
i ran it for a while on my h22a hatch.
i had great power below 3500 rpm and above 6000rpm, but midrange was abyssmal. i also passed emissions with it too though.
i would not recommend a stoock p72 if you want power out of your engine. best thing to do with it is hondata or chip it with an h22a specific map.
chameleon
Jul 29, 2002 08:26 PM
