ABS accumulator questions, Which will fit, where is it, how much? HELPPPP
Old Nov 24, 2003 | 09:01 PM
EGcivicBoy's Avatar
Default ABS accumulator questions, Which will fit, where is it, how much? HELPPPP
Please Help.. in need of ABS
Well it's winter time in Washington and my ABS system sucks. Ive posted before and people say i need a new ABS accumulator. I loose pressure in my brake system ALL the time.. every couple mins.. Makes a clicking noise, and yes my ABS light comes on sometimes
I feel like im drivin a 67 ford when you have to pump the damn brakes.
My car- 1995 Civic Ex
Will a accumulator for a 94 gsr or a 95 integra fit? If so or not which ones will fit?
Where is the thing at, does anyone have a picture?
And how much do you think a used one should go for?
If you have one for sale PM me, if you have pics post them...
Help me! thanks
Old Nov 24, 2003 | 09:29 PM
EGcivicBoy's Avatar
Default Re: ABS accumulator questions, Which will fit, where is it, how much? HELPPPP (EGcivicBoy)
help
Old Nov 25, 2003 | 04:02 AM
JimBlake's Avatar
Basics first!! Have you bled your brake system? Have you bled your ABS system? You need clean fluid with no air bubbles first, before you panic.
Pumping the brakes sounds like air in the main brakes. That's not the same problem as your ABS loosing pressure.
I don't know which accumulators fit. The ABS unit in my '95 Integra is at the far right-forward corner of the engine compartment. The accumulator looks like a little bottle attached to the ABS unit.
Old Nov 25, 2003 | 07:00 AM
EGcivicBoy's Avatar
Default Re: ABS accumulator questions, Which will fit, where is it, how much? HELPPPP (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Basics first!! Have you bled your brake system? Have you bled your ABS system? You need clean fluid with no air bubbles first, before you panic.
Ya ive bled it. Look here https://honda-tech.com/zerothread?id=666723
Old Nov 25, 2003 | 07:49 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGcivicBoy &raquo;</TD></TR><TR><TD CLASS="quote">Ya ive bled it...</TD></TR></TABLE>OK, sorry. When you said you had to pump the brakes that really sounded like air in the lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGcivicBoy &raquo;</TD></TR><TR><TD CLASS="quote">I feel like im drivin a 67 ford when you have to pump the damn brakes.</TD></TR></TABLE>Dang. I learned to drive on 64 & 67 Fords. Makes me feel OLD But I didn't have to pump the brakes. They WORKED.
lesagueneen
Honda Fit
Jul 22, 2018 10:11 AM
jonzel
Aug 18, 2005 04:47 PM
EGcivicBoy
Nov 29, 2003 11:58 PM
EGcivicBoy
Nov 25, 2003 04:32 AM
oioioi
Jan 23, 2003 02:56 PM
