a question about the prelude doors ..
what if your door is stuck from inside and outside .. like you cant open it from the inside and outside .. is there anyway to open the door ???
remove interior door panel and see why your handles don't work.
its pretty obvious how everything is supposed to be hooked up once you get the panels off.
what if my panels are still there ... and my 2 screws cant come out .. because my door is close .. so is there any other way .. cuz i dont think i can take out my panel... thanx man .. any other suggestions ?
Have you already tried removing the handle (the lever to open the door from the inside)? Once removed, you should be able to pull the lever that actually connects to the door handle on the inside.
USDM DC4
May 19, 2007 06:19 PM
