What kind of clusters are Plug-and-play??
Old Nov 24, 2003 | 08:00 PM
youngwon22's Avatar
Default What kind of clusters are Plug-and-play??
I don't like the look of a crx cluster. They are pretty ugly i want to get a cluster from a different car, and i don't know which one would fit.
Is there any cluster that is a plug and play deal? If not what's the easiest work that can be done? Wiring is the subject i'm not good at, so i'm here again, asking for your help. Thanks
Old Nov 24, 2003 | 08:54 PM
JonGP4's Avatar
Default Re: What kind of clusters are Plug-and-play?? (youngwon22)
nothing different looking will plug right in, any other cluster will require some wiring.. and if you can't wire, then guess ur stuck with the stock one
Old Nov 24, 2003 | 10:16 PM
X-Static's Avatar
your lame EF clusters own
Old Nov 24, 2003 | 11:09 PM
drjondurst's Avatar
Default Re: What kind of clusters are Plug-and-play?? (X-Static)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static &raquo;</TD></TR><TR><TD CLASS="quote">your lame EF clusters own
amen
Old Nov 24, 2003 | 11:25 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: What kind of clusters are Plug-and-play?? (drjondurst)
if you look around.. maybe some old posts.. archived.. they'res DC2 and new clusters in our oldie but goodies.. just do alittle research. and homeys right, it would have to be re pinned.
Old Nov 25, 2003 | 01:44 AM
Alan Wil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngwon22 &raquo;</TD></TR><TR><TD CLASS="quote">I don't like the look of a crx cluster. They are pretty ugly i want to get a cluster from a different car, and i don't know which one would fit.
Is there any cluster that is a plug and play deal? If not what's the easiest work that can be done? Wiring is the subject i'm not good at, so i'm here again, asking for your help. Thanks</TD></TR></TABLE>
youngwon22,
First of all your going to have to fix that speedo cable before ANY cluster will work.
https://honda-tech.com/zerothread?id=664753
I put a 89ish CRX cluster in my 90 DX... It was not plug and play... Many wires had to be rerouted to differant pins.. and four wires needed to be swapped from multi-pulg to multi-plug if memeory serves me right.
Old Nov 25, 2003 | 02:26 AM
Built B16A's Avatar
Default Re: What kind of clusters are Plug-and-play?? (Alan Wil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alan Wil &raquo;</TD></TR><TR><TD CLASS="quote">First of all your going to have to fix that speedo cable before ANY cluster will work..</TD></TR></TABLE>
good call, i forgot about that.. i have the EF8/9 cluster in mine, and a dandy little obd1 VSS.
Old Nov 25, 2003 | 03:00 AM
Alan Wil's Avatar
Default Re: What kind of clusters are Plug-and-play?? (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
good call, i forgot about that.. i have the EF8/9 cluster in mine, and a dandy little obd1 VSS. </TD></TR></TABLE>
The guy (youngwon22) who was asking can't even find the speedo cable on his car. https://honda-tech.com/zerothread?id=664753
He first needs to fiqure out "why' the speedo cable isn't turning... (LOL)..Then worry about swapping clusters and such.
Old Nov 25, 2003 | 01:46 PM
youngwon22's Avatar
youngwon22,
I put a 89ish CRX cluster in my 90 DX... It was not plug and play... Many wires had to be rerouted to differant pins.. and four wires needed to be swapped from multi-pulg to multi-plug if memeory serves me right.</TD></TR></TABLE>
Yea I know, but i still want a new cluster
Old Nov 25, 2003 | 01:55 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngwon22 &raquo;</TD></TR><TR><TD CLASS="quote">street racing under influence is fun....... </TD></TR></TABLE>
For even suggesting 2 dumbs things at once
You can have anything you want as long as its a corona brian.........
just dont pull that **** around me.
Old Nov 25, 2003 | 02:02 PM
Alan Wil's Avatar
Yea I know, but i still want a new cluster </TD></TR></TABLE>
Well in that case you need to be able to fiqure out the pin-outs of the cluster you want to use. I wish I could tell you what fits whats without rewiring but I can't. I can just relay what I had to do.
If it was me.. I'd look for a cluster from the same year models. I think the cluster I used was from a 89ish car... so going into a 90 model DX required re-wiring.
It's not hard IF your skill level is high enough. Seeing your other post about the Speedo cable... I wonder.
Regardless to get any cluster to work your going to have to fiqure out why the speedo cable isn't turning.
Old Nov 30, 2003 | 06:37 PM
youngwon22's Avatar
thanks for all the info so far....but this one has NOTHING TO DO WITH MY OTHER TOPIC, WHICH HAS TO DO WITH FIXING MY SPEEDO. I am just trying to get a cluster for the future.
So would 89 integ cluster fit?
Old Nov 30, 2003 | 06:52 PM
fourthgenhatchB17's Avatar
Default Re: What kind of clusters are Plug-and-play?? (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
just dont pull that **** around me.</TD></TR></TABLE>
hahaha
Old Nov 30, 2003 | 06:54 PM
Alan Wil's Avatar
So would 89 integ cluster fit?</TD></TR></TABLE>
Youngwon22,
How do you propose to get that cluster to work if the pinouts are differant if you can't even fix /replace a broken speedo cable?
Old Nov 30, 2003 | 07:01 PM
youngwon22's Avatar
Youngwon22,
thats what im about to find out : if the pinouts fit and broken/ not broken cable does not matter right now ok?
Old Nov 30, 2003 | 07:17 PM
Alan Wil's Avatar
thats what im about to find out : if the pinouts fit and broken/ not broken cable does not matter right now ok?</TD></TR></TABLE>
The plugs will more that likely physically plug into either cluster. Even if they don't you could swap the plugs from the Integra harness onto the Civic...
Have you seen an Integra cluster up close and compared it to the Civic cluster in the car now? (The back side not the front) It should work but some pin-outs will be in different places. Just get out your shop manual and an ohmmeter and track down which trace goes to what. No big deal really.
Old Dec 1, 2003 | 02:24 AM
jessevtec's Avatar
so will a 97 on up us ITR gauge cluster work on a 90 crx as well with a obd1 vss?
Old Dec 1, 2003 | 12:18 PM
Built B16A's Avatar
Default Re: (jessevtec)
do alittle research.. there is a topic archived in here with a EF running around wiht a DC2 cluster in his pimp-mobile.. do reasearch. it came out pretty damn clean if you ask me.. exept one screw.. maybe he could of used a black one? dunno?
Old Dec 2, 2003 | 01:50 PM
youngwon22's Avatar
will a 90-91 cluster housing fit ( housing=the cover...? dont know but i think thats what its called)
Ray Satomi
Apr 17, 2017 07:42 PM
tast2s
Aug 23, 2012 08:21 PM
redboy183
Nov 30, 2007 08:00 AM
punkhop83
Oct 25, 2005 05:50 PM
