Boosted ITR engine - smoke from engine bay
Old Nov 24, 2003 | 06:58 PM
peterfurnival's Avatar
Default boosted type r ... read
i have a type r engine and i have a gsr greddy turbo. i have smoke coming from the engine bay and i cant find where it is coming from. this happened to anyone? got the bigger raditor and thin fans also no i/c. please let me know. untunned stock internals. also if you are reading this and have boosted ur type r please post ur set up and dynos if u got em
pete
Old Nov 24, 2003 | 07:07 PM
.RJ's Avatar
.RJ
Default Re: boosted type r ... read (peterfurnival)
Well you've got an oil leak.... find it
Old Nov 24, 2003 | 07:29 PM
CrazyHondaBoy's Avatar
Default Re: boosted type r ... read (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Well you've got an oil leak.... find it </TD></TR></TABLE>
Bingo! Go check by the header between the exhaust pipe. Oil leak can be there, burning oil, causing white smoke, check oil return line, head gasket, head disp cap for any oil leak.
Old Nov 24, 2003 | 07:47 PM
chad's Avatar
Moderator
maybe not....maybe coolant....maybe exhaust.....
didn't say at what speed, ie idle etc...
Old Nov 24, 2003 | 08:35 PM
Dr Pooface's Avatar
Default Re: boosted type r ... read (chad)
what does the smoke smell like?
Old Nov 24, 2003 | 09:37 PM
jdmspoonitr's Avatar
Default Re: boosted type r ... read (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">what does the smoke smell like?</TD></TR></TABLE>
If it smells a little sweet it's coolant. If the smoke has a blue tint it's the oil.
Old Nov 25, 2003 | 05:20 AM
turboHX's Avatar
this is a little off topic but how much boost u running on ur stock ITR. I'm about to boost mine but I thought the compression was too high to boost it.
Old Nov 25, 2003 | 08:29 AM
01ITR#700's Avatar
Default Re: boosted type r ... read (turboHX)
Did I read that correctly? No intercooler? Untuned?
It's too hard to guess where the smoke is coming from or what is causing it without being able to look at the car.
Mark
Old Nov 25, 2003 | 08:59 AM
thanks fo rall the replys i still cant find the leak im considering selling my turbo or at least taking it off. only 5 pounds of boost
Old Nov 25, 2003 | 09:01 AM
Racing is one of the finest mechanisms for the disposal of money - Scott (RR98ITR)
true to that
Old Nov 25, 2003 | 09:05 AM
my idle also bounces up and down when the cars cool it s fine when i warms up it ready to stall. i thought it was a vacume leak but after a weekend of trying to find that leak i have given up. the manifold als oget extreemly hot as soon as i turn on the car. the smoke normally comes after the car trys to boost. if anyone can help i would be very thankful.
Old Nov 25, 2003 | 09:22 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peterfurnival &raquo;</TD></TR><TR><TD CLASS="quote">thanks fo rall the replys i still cant find the leak im considering selling my turbo or at least taking it off. only 5 pounds of boost</TD></TR></TABLE>
That's a good idea.
Wait until you can do the thing right, ie. properly tuning it and buying a nice intercooler.
Old Nov 25, 2003 | 10:01 AM
Honky-Tech's Avatar
Check all ur lines and hoses 2 make sure they r on tight (for the smoke problem). U might have bent a rod(for the idle problem) but only runnin 5 lbs of boost, it would b odd.
Old Nov 26, 2003 | 11:09 AM
Jon D's Avatar
Check your pcv valve..........often time you can have oil leak from there and not even know it. It will drip down and take a while to burn off. Just a suggestion, if its so bad you can smell it though thats probably not it.
Old Nov 26, 2003 | 11:31 AM
Evs-One's Avatar
Solbros Owns Me
ITR's love boost..
I'm a big fan of high comp and boost
oprac
12
Aug 15, 2007 11:45 AM
jli18
Feb 19, 2006 07:33 PM
Kirk@SyndromeAuto
Apr 2, 2005 02:10 PM
Sam
May 17, 2004 07:28 PM
BluePrelude01
Apr 5, 2003 10:58 PM
