high compression valves
When my timing belt went I guess some valves got bent in the process. about how much would high comp valves raise my overall compression. also seeing as im damn near broke would I be hurting anything if I drove around on a few bent vlaves? Im looking for oppinions on wether high comp valves are a worthey upgrade or not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam »</TD></TR><TR><TD CLASS="quote">valves dont rasie compression, pistons do</TD></TR></TABLE>
**shakes head**
**shakes head**
LOLOLOOL
LOLOLOOL
No, silly.........Valves dont raise compression, milled heads do.
You don't get out much do you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus »</TD></TR><TR><TD CLASS="quote">
You don't get out much do you?</TD></TR></TABLE>
then someone please tell me how valves rasie compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>i was just giving the simplest answer
then someone please tell me how valves rasie compression?</TD></TR></TABLE>
The valve face is flat, not concaved. That occupies more space in the combustion chamber, and incerases compression.
The valve face is flat, not concaved. That occupies more space in the combustion chamber, and incerases compression.</TD></TR></TABLE>
yea, but the increase is so little, i hardly call that "high compression", you wouldn't raise the compression enough to get a noticeable power increase except on a dyno, and even then, it wouldnt hardly be visible just to look at the graph
yea, but the increase is so little, i hardly call that "high compression", you wouldn't raise the compression enough to get a noticeable power increase except on a dyno, and even then, it wouldnt hardly be visible just to look at the graph</TD></TR></TABLE>
.3-.5 isnt exactly a small increase
11seclude
Sep 3, 2005 01:33 PM
