what mounts are compatible with a b16 in 92-95 hatch
Old Nov 24, 2003 | 04:20 PM
forever slow EG6's Avatar
Default what mounts are compatible with a b16 in 92-95 hatch
My problem is that I have stock mounts that came with the SIRII motor, and my drivers side mount is now busted. I can't find a used Del Sol mount, and I'm not willing to buy a whole new aftermarket mount kit.
what cars can I take a used mount from?
Old Nov 24, 2003 | 04:23 PM
JaeOne3345's Avatar
Default Re: what mounts are compatible with a b16 in 92-95 hatch (forever slow EG6)
any 94-01 integra should work.
If you find a single cam with the silver driver side mount, i believe its top half will work just fine.
Old Nov 24, 2003 | 04:26 PM
chad's Avatar
Moderator
depends on what your BRACKET looks like....
if it is 3 hole you need one from a gsr...if it is 2 hole offset you can probably use a civic mount...
Old Nov 24, 2003 | 04:34 PM
Thanks much guys.
ewok1
Jun 13, 2012 04:17 AM
8520
Jul 25, 2007 01:41 PM
CRX MASE
May 5, 2005 08:32 PM
0554
10
Mar 5, 2003 10:29 PM
Red_hatch
Jan 3, 2003 12:39 PM
