JDM ITR in 00' LS...throwin codes 7 and 10!
Old Nov 24, 2003 | 03:47 PM
its WANG yoO's Avatar
Default JDM ITR in 00' LS...throwin codes 7 and 10!
just finished my swap...throwing codes 7-TPS and 10-IAT...i broke the TPS doin the swap..so i replaced it..car idles at 1500-2000..and the IAT wires are correct...where are these codes coming from...and why is it idling high?
Old Nov 24, 2003 | 05:55 PM
Default Re: JDM ITR in 00' LS...throwin codes 7 and 10! (inJDMtegra)
someone knows this...
Old Nov 24, 2003 | 06:28 PM
Dancing is Forbidden's Avatar
did you reset the ecu?
Old Nov 24, 2003 | 07:52 PM
Newman's Avatar
New User
TPS - make sure it's aligned & calibrated. Any & all Honda TPS's will work on the motor.
IAT - OBD-2 cars have the IAT sensor in the intake arm (before the throttle body). On OBD-1 cars, it's on the intake manifold. You need to extend the wires & move the sensor to the appropriate place.
Old Nov 25, 2003 | 06:07 AM
4U2NV's Avatar
Default Re: JDM ITR in 00' LS...throwin codes 7 and 10! (Newman)
On my 99 LS my IAT was a small plug on my IM... I know on Civics, the IAT is in the intake arm, but on Teg's it should be held down by two screws on runner number 2 on the IM... Is there a plug there on the ITR IM...?
Old Nov 25, 2003 | 03:20 PM
i want a civic's Avatar
Default Re: JDM ITR in 00' LS...throwin codes 7 and 10! (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">On my 99 LS my IAT was a small plug on my IM... I know on Civics, the IAT is in the intake arm, but on Teg's it should be held down by two screws on runner number 2 on the IM... Is there a plug there on the ITR IM...?</TD></TR></TABLE>
Yupp he's right i had the same code!!..if the wiring is right check the actual sensor my sensor was fried and we checked out the ring milions of times until i pulled the actual sensor.. ..lol
Old Nov 28, 2003 | 05:26 AM
Default Re: JDM ITR in 00' LS...throwin codes 7 and 10! (i want a civic)
ya the sensor is on the intake manifold...should i just take it out and replace it? what color wires go there?
dohc_profile
Jul 5, 2008 09:26 AM
lojackgsr
Jan 16, 2007 10:35 AM
TheNasty0ne
14
Apr 19, 2005 10:43 AM
FredoSP
Jan 8, 2004 09:10 AM
voltageGSR
Dec 8, 2003 05:43 AM
