fitment of ctr/itr steering wheel
Old Sep 14, 2001 | 09:22 AM
EkREV's Avatar
New User
Default fitment of ctr/itr steering wheel
is there a difference in fitment onto a 98 ek for a ctr or itr steering wheel with airbag? also, does the year of steering wheel matter due to the wiring of the airbag. i am planning on getting a ctr/itr steering wheel for my car but i am afraid of losing my airbag function.
Old Sep 14, 2001 | 11:38 AM
bhcvc's Avatar
Default Re: fitment of ctr/itr steering wheel (jdm ek)
I haven't done this, but I've been told that the CTR wheel will fit, but the ITR won't. As for the harnesses, if they're not direct fit, you can use some wires to connect what's needed. Just make sure to solder everything for a good, secure connection. HTH.
Old Sep 14, 2001 | 03:00 PM
eg6ajk's Avatar
if you have a EK, then only a EK9 or CTR steering wheel will work, DC or ITR uses the same hub as EG civic so its no go...
Old Sep 14, 2001 | 09:11 PM
clockworks's Avatar
Default Re: fitment of ctr/itr steering wheel (eg6ajk)
Anyone know the diameter of the CTR wheel?
Old Sep 15, 2001 | 06:28 AM
eg6ajk's Avatar
Default Re: fitment of ctr/itr steering wheel (clockworks)
not the best answer but compared to my MOMO Corse my old JDM ITR/CTR (they are the same with a difference in the hub) which is 350mm, it was the almost the same....
so 350-360mm is about right
neo_
Feb 26, 2009 05:50 PM
924doorEG
Apr 23, 2008 08:00 PM
machgo5go
Dec 9, 2007 04:56 PM
Type R106
Jun 30, 2001 07:39 AM
