New fuel tanks for MPFI swap?????
Old Nov 24, 2003 | 02:23 PM
youngwon22's Avatar
Default New fuel tanks for MPFI swap?????
I've been searching for info on mpfi swap. I've heard from tons of people saying that all you need is complete manifold, dist, ecu, and resistor box.
I went to a new import shop in town, they do all the labor work, and i asked about mpfi swap and all the mechanics there were sayin that i need to change the fuel tank because stock dpfi engine wont return right amount of fuel (wasnt paying attention) so you would have to get si fuel lines or somethin that required them to drop the gas tank. Is this true? or are they just trying to make more money?
if it's true, what would i need for mpfi swap? Thanks and i did search but i MIGHT have missed one that had this info but im pretty sure i didnt but let me know. Thanks for any replies
Old Nov 24, 2003 | 02:25 PM
kid-honda's Avatar
Full intake manifold
ECU
Resistor pack
Dist
a few plugs and pins and some wire.
Nothing that has to do with the gas tank.
They are idiots and this is easy so do it yourself.
Old Nov 24, 2003 | 03:01 PM
onePOINTsix's Avatar
Default Re: (kid-honda)
Old Nov 24, 2003 | 03:11 PM
88 rex's Avatar
Default Re: (Sideout)
I wouldnt go back to that shop again........
Old Nov 24, 2003 | 03:12 PM
Malgerus's Avatar
OMG....
A new fuel pump? First time I've heard of this. My friend is running an OBD-I Type R engine into the low 13's on an HF pump, and it's still going strong!
Old Nov 24, 2003 | 03:27 PM
88 rex's Avatar
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">OMG....
A new fuel pump? First time I've heard of this. My friend is running an OBD-I Type R engine into the low 13's on an HF pump, and it's still going strong!</TD></TR></TABLE>
Now i have heard of people having issues with fuel supply from the stock fuel pumps on B16's and c5's......At some point an upgrade can only help........MPFI is def not worthy of a fuel pump or fuel tank upgrade.
Old Nov 24, 2003 | 03:41 PM
Malgerus's Avatar
Default Re: (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">
Now i have heard of people having issues with fuel supply from the stock fuel pumps on B16's and c5's......At some point an upgrade can only help........MPFI is def not worthy of a fuel pump or fuel tank upgrade.</TD></TR></TABLE>
True, but that's only when the pump is about to take a dump. Stock lph is adequate when functioning properly. You can also increase voltage to pump to increase flow rate (at the cost of longevity, I would think).
EDIT:I played it safe and I'm running a Walbro 190lph.
Old Nov 24, 2003 | 07:53 PM
youngwon22's Avatar
So? should i get a fuel tank/pump/anything?
Old Nov 24, 2003 | 07:54 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt go back to that shop again........ </TD></TR></TABLE>
i can't count how many mpfi swaps i have done and NOT ONCE did i change the fuel tank or fuel pump
Old Nov 24, 2003 | 07:55 PM
Bunger's Avatar
Default Re: (youngwon22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngwon22 &raquo;</TD></TR><TR><TD CLASS="quote">So? should i get a fuel tank/pump/anything?</TD></TR></TABLE>
Nope... use the stock stuff, its the same thing...
Old Nov 24, 2003 | 08:02 PM
youngwon22's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
i can't count how many mpfi swaps i have done and NOT ONCE did i change the fuel tank or fuel pump</TD></TR></TABLE>
JW, how was your gas milege? still good? or little more gas?
youngwon22's Avatar
Uuuuuuummmmmmm............whats a lph??
Old Nov 25, 2003 | 08:58 PM
evilxkid's Avatar
don't listen to those guys man, they just pay jessy to do the conversion for them any ways. you should talk to him direct.
and no you don't need a new tank. hahaha.......
Old Nov 25, 2003 | 10:11 PM
MestizoRacer310's Avatar
Can you be a little more specific?? What ECU would I need? What other stuff would I need to make this work on my EF2 LX?? Also wouldn't it just be easier to run a MSD external box and coil (and stuff like that?)
Also LPH stands for Litres Per Hour. Nothing more than a flow rate.
Old Nov 26, 2003 | 01:46 AM
.cingham's Avatar
i wonder if he went to IVM...infinate violate your honda motorsports
Old Nov 26, 2003 | 02:40 AM
Caleb V's Avatar
The idiots at the shop are thinking about a Mk.1 1984-1987 carbed CRX to Fuel injection swap. You don't need to change anything in the fuel supply system up to the firewall in a 1988-1991 USDM car.
Depends on what motor you are running if you are installing a D16A6 you need a Pm6 ecu. If you need a harness built let me know I build them all the time.
Old Nov 26, 2003 | 01:43 PM
youngwon22's Avatar
Default Re: (evilxkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">Can you be a little more specific?? What ECU would I need? What other stuff would I need to make this work on my EF2 LX?? Also wouldn't it just be easier to run a MSD external box and coil (and stuff like that?)
Also LPH stands for Litres Per Hour. Nothing more than a flow rate.</TD></TR></TABLE>
who are you talkin to, and how did this whole ecu subject come up
Modified by youngwon22 at 4:15 PM 11/28/2003
Old Nov 27, 2003 | 01:22 PM
.cingham's Avatar
someone needs to do some reading, use the search option on this board, and go to the hybrid.jp info pages.
Old Nov 28, 2003 | 03:13 PM
youngwon22's Avatar
Default Re: (cingham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cingham &raquo;</TD></TR><TR><TD CLASS="quote">someone needs to do some reading, use the search option on this board, and go to the hybrid.jp info pages.</TD></TR></TABLE>
ive done search and some reading dont need you to say nothin on this board
Old Nov 28, 2003 | 09:13 PM
.cingham's Avatar
hmm obviously not enough, especially if your asking about swaping out the fuel tank. Don't bite the hand trying to feed you
Old Nov 29, 2003 | 03:48 PM
youngwon22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cingham &raquo;</TD></TR><TR><TD CLASS="quote">hmm obviously not enough, especially if your asking about swaping out the fuel tank. Don't bite the hand trying to feed you</TD></TR></TABLE>
well dont be teasing the one your feeding before he eats you
Old Nov 30, 2003 | 10:32 AM
.cingham's Avatar
thats why news papers are good to smack dogs across the face
Old Nov 30, 2003 | 12:37 PM
youngwon22's Avatar
hahaha right
East_McDuck
Sep 24, 2010 03:05 AM
brownsEF
Mar 23, 2009 03:38 PM
sIcKvIc
Mar 23, 2005 02:48 PM
mikensu
Dec 2, 2004 07:09 AM
Layziebtnh055
Apr 15, 2004 05:40 AM
