Problem: Brake line install...
hey guys,
was in the process of removing the stock rubber brake lines for SS bling lines, and while working on it with a friend he removed the metal clip that holds the brake line from moving..
Well after investigating for awhile and purchasing a flare wrench, I tried to loosen that nut for the line w/o the clip. Since the clip isnt there, the brake line moves freely. We tried to jam the clip back in there to stop movement, but it still moves a little..
Any suggestions, or am I screwed..?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">you need 2 flare wrenches.
lots of liquid wrench.</TD></TR></TABLE>
Yup and be careful you don't strip those suckers-
use a vice grips on the lil metal bracket just to hold it in place. that's what we did...
| | hard line
|nut|__
| ___| vice grips here. so it doesn't turn
| | rubber tubing
u can use regular plyers, but something a lil more sturdy are the vice grips. it's not bending anything else, it's a solid piece of metal.
| | hard line
|nut|__
| | rubber tubing
Redline96LX
Jan 6, 2006 06:05 PM
