b18a1 compared to b18b
Old Nov 24, 2003 | 11:55 AM
Sammex's Avatar
Default b18a1 compared to b18b
I noticed that there is some power differences between the two. Is it true that most of the difference is from the different intake manifolds? Another question, a local guy is selling a complete b18a1 swap for a crx (axles, mounts, linkage, etc. ,) for 1000 with supposively 53k miles on it, is this a good deal?
Old Nov 24, 2003 | 12:01 PM
89Si's Avatar
Default Re: b18a1 compared to b18b (Sammex)
i believe the b18b has better cams plus the different manifold. and that deal sounds pretty damn good to me
Old Nov 24, 2003 | 12:04 PM
Sammex's Avatar
well the engine is still in the crx so i can test drive it. Is there a power difference between the obdo and obd1 b18a's
Old Nov 24, 2003 | 12:21 PM
streetrage's Avatar
the 90-91 Ls is rated at 130 hp, and the 92-93 (OBD1) Ls is rated at 140. the cams are supposed to be the difference. The 94-up Ls is rated at 142 hp because of the wilder cams and the intake manifold....
Alex
Old Nov 24, 2003 | 01:00 PM
brent_G's Avatar
Default Re: (streetrage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrage &raquo;</TD></TR><TR><TD CLASS="quote">the 90-91 Ls is rated at 130 hp, and the 92-93 (OBD1) Ls is rated at 140. the cams are supposed to be the difference. The 94-up Ls is rated at 142 hp because of the wilder cams and the intake manifold....
Alex</TD></TR></TABLE>
thats what iw as gonna say pretty much.
90-91 is like a dohc zc with more torque.
Old Nov 24, 2003 | 02:13 PM
EL Vap133's Avatar
That sounds like a good deal to me...
Old Nov 24, 2003 | 03:34 PM
ThatRicerDaniel's Avatar
Default Re: b18a1 compared to b18b (EL Vap133)
not the cams. im not sure but i know its not the cams for sure cuz we measured them on the lobes with this measurement tool my friend had. i would assume the intake mani being one part of it and maybe better profiles in the ecu department. just a guess though.
Old Nov 24, 2003 | 09:06 PM
Sammex's Avatar
Thanks for the replies, since its obdo, will this yield of having hondata?
Old Nov 24, 2003 | 11:04 PM
89s1's Avatar
Default Re: (Sammex)
I heard hondata's work better with an obd1 ayatem.
Old Nov 25, 2003 | 10:13 AM
streetrage's Avatar
I believe Hondata doesn't work with OBD0. The only one I heard that does is Zydyne.
NitrousDreamz: You measured the cams, and they're the same? From what engines? 94-up of 92-93? 90-91? I heard they were different...
Alex
Old Nov 25, 2003 | 03:44 PM
it was a b18a and a b. dont know if it was 90-91 or 92-93.
Old Nov 25, 2003 | 08:19 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrage &raquo;</TD></TR><TR><TD CLASS="quote">I believe Hondata doesn't work with OBD0.</TD></TR></TABLE>
The only pre-1992 ECU that Hondata will modify is the B16A PR3/PW0. As for B18A/B18B differences, another is the head. The B18B head has bigger intake ports.
tractionless
Apr 25, 2006 08:02 PM
trustnoone7935
Aug 15, 2005 07:22 PM
quicksol95
May 17, 2005 03:30 PM
B18aHatch
Sep 30, 2004 11:00 PM
import_racer_ky
Sep 6, 2003 08:25 PM
