what color is your clutch masters PP?
Old Nov 24, 2003 | 11:23 AM
xXx Justin xXx's Avatar
Default what color is your clutch masters PP?
i bought a turbo kit with extras from a guy on here. everything looks wonderful. said it was a clutch masters stage 3. the PP is red ( no lettering on it anywhere, just scraped up all the way around where the writting would normally be)
and it is a 6 puck disk.... he said he used it for 6k miles, then put his car to stock and sold the bolt ons.
anybody have a clutch masters clutch that sounds as i described it?
Old Nov 24, 2003 | 11:25 AM
chad's Avatar
Moderator
Default Re: what color is your clutch masters PP? (SOHC Beast)
my clutch master stage 3 is yellow...for bseries....maybe it is red for d series!?!?
Old Nov 24, 2003 | 11:34 AM
ill phil's Avatar
Default Re: what color is your clutch masters PP? (chad)
Wow I have really shitty memory, I was going to say my stage 4 is white... but no telling may be yellow. I could have sworn it was white though.
Old Nov 24, 2003 | 11:57 AM
redline201's Avatar
im pretty sure my stage 3 for my b16a was white
Old Nov 24, 2003 | 12:37 PM
EL Vap133's Avatar
Default Re: what color is your clutch masters PP? (redline201)
When I bought the Clutchmasters street/strip setup that totally sucked *** cause it didn't even last me a year, it was white....
Old Nov 24, 2003 | 12:38 PM
DaX's Avatar
DaX
Loved
Community Favorite
Stage 3 for mine is white.
Old Nov 24, 2003 | 12:39 PM
Jonathan_ED3's Avatar
My stage 3 was white on my H22.
Old Nov 24, 2003 | 12:48 PM
TeamNextGenChris's Avatar
yup,stage 3 for my b-series was white...but that was over three years ago.
chris
Old Nov 24, 2003 | 12:58 PM
Default Re: what color is your clutch masters PP? (TeamNextGenChris)
ok, well anybody have any guesses who makes a clutch with a red PP? thanks
Old Nov 24, 2003 | 01:02 PM
quickchris's Avatar
i know that clutchmasters are white for b and h-series,for stage 1tru4,,,,now the stage 5 is red.I sell clutchmaster clutches all day long.Hope this helps.
Old Nov 24, 2003 | 01:53 PM
Default Re: (quickchris)
this is d series clutch.... stage 5... is that even streetable? and would it work as well as a lower stage. as far as producing power? my friend had a b16 imported. it came with a clutch that looks identical to this one... no labels. car never seemed as fast as it should have been. somebody else put his engine in a old teg, only thing that was used different was a different clutch.. and slightly smaller injectors ( somebody sold him aftermarket bigger injectors when he thought he bought stock) and the car tuned dynoed 17whp more.... just from taking out the rediculously heavy duty clutch and running correct injectors. if you can follow that crap... please answer the question:
Old Nov 24, 2003 | 02:15 PM
chad's Avatar
Moderator
Default Re: (SOHC Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Beast &raquo;</TD></TR><TR><TD CLASS="quote">this is d series clutch.... stage 5... is that even streetable? and would it work as well as a lower stage. as far as producing power? my friend had a b16 imported. it came with a clutch that looks identical to this one... no labels. car never seemed as fast as it should have been. somebody else put his engine in a old teg, only thing that was used different was a different clutch.. and slightly smaller injectors ( somebody sold him aftermarket bigger injectors when he thought he bought stock) and the car tuned dynoed 17whp more.... just from taking out the rediculously heavy duty clutch and running correct injectors. if you can follow that crap... please answer the question:
would it work as well as a lower stage. as far as producing power?</TD></TR></TABLE>
anything is streetable....depending on the driver!!! i daily drive with a single plate exedy hypersingle clutch....no interior....no door windows.....gutted....and i say the car is a daily driver....but to each his own
Old Nov 24, 2003 | 02:27 PM
Default Re: (chad)
well i drive about 400 miles a week.... i dont wants something that jerks the car when you start letting the clutch out...... any opinions on the hp deal that my friend experienced with his b16... the clutch grabbed hard, never slipped, but was killing power for some reason?
Old Nov 24, 2003 | 02:29 PM
EG2 SiR's Avatar
I had a "Valley Clutch" dual diaphram pressure plate that was red... But they are local to So Cal.... Where did you get it?
Old Nov 24, 2003 | 03:09 PM
Default Re: (EG2 SiR)
the guy used to live in CA i think. then moved to Las Vegas and put his car to stock cuz he needed money to live...the clutch came with the turbo stuff... along with other extras.
did it have a 6 puck disk?
Old Nov 24, 2003 | 03:12 PM
EG2 SiR's Avatar
they offer a lot of different discs. If you can take a pic. I can tell you if it looks like mine used to.
Old Nov 24, 2003 | 07:03 PM
EGtoDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline201 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure my stage 3 for my b16a was white</TD></TR></TABLE>
word. I JUST PUT A stage 3 CM with CM flywheel in my Bseries today, it was white.
Old Nov 24, 2003 | 07:05 PM
minivan81's Avatar
Default Re: what color is your clutch masters PP? (EGtoDC2)
My CM stage 5 PP was white.
Old Nov 24, 2003 | 08:16 PM
2000Ek's Avatar
How does the CM stage 3 feel with the Lightended Flywheel? I am looking to put the same set up in my B series. CM stage 3 is white, Yellow is ACT.
Old Nov 24, 2003 | 11:25 PM
EGtoDC2's Avatar
Default Re: what color is your clutch masters PP? (2000Ek)
i'll tell ya in the next few days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000Ek &raquo;</TD></TR><TR><TD CLASS="quote">How does the CM stage 3 feel with the Lightended Flywheel? I am looking to put the same set up in my B series. CM stage 3 is white, Yellow is ACT.</TD></TR></TABLE>
negusjuda
27
Feb 11, 2011 03:51 AM
B16Civic93
Mid-Atlantic (Sales)
Aug 27, 2009 02:41 PM
vtecspeed1320
May 10, 2006 07:03 PM
spooncivic1
Apr 25, 2005 10:13 AM
98ITR#0020
May 18, 2004 10:02 AM
