my head/TB/Mani pics
Here are pics of my Accord head from BCE "Bill" He used Rev products ,valves , springs, retainers. He also ported my intake Manifold since nobody makes one for us.. and bored out a h22 T/B for me also.. I will have pictures of my sleeved Benson Block up later too. 89mm bore
Crower Rods, CP pistons..
Modified by Globalundrground at 8:35 PM 11/24/2003
Modified by Globalundrground at 8:36 PM 11/24/2003
Modified by Globalundrground at 8:39 PM 11/24/2003
Modified by Globalundrground at 2:11 AM 11/25/2003
hey hey looking good! i'm planning to go with benson too! how much did the block cost you all together?
also did you match the combustion chamber of the head with the over bore block?
what's your setup?
what's your setup?
Yes, it got un shrouded to match the bore size.
Block, i bought the CP's from Dan also and had him assemble the block too, all together for everything was $2200 shipped included all machine work, removal of balance shafts, sleeved, balancing with clutch and flywheel.
Dont know what Turbo yet, im leaving in March to"Army Basic" so i just want to get the motor in there all-motor to start-up till i get to my first base. THen i will work with the propper turbo size ect...
I have a Accel DFI computer waiting for the turbo stuff also.
yes i have the receipt at the house, i will give the list of parts ect.. later when i get home.
Compression 9:0:1
you can reach dan at 714-241-1284
It takes a day usually for him to return your call.. busy man.
Compression 9:0:1
looks nice and sounds like a legit setup. im not familiar w/ CP pistons, whats the story behind them? do they make high compression/custom units? highest comp shelf piston ive found is the 11:1 RE/Wiseco....i need something higher than that. also looking for something in about a 90mm bore....
http://www.ef-1.com is a large supplier of them...they make some crazy compression pistons if you really want them...ef-1 has some good stuff as well for good prices!
price break down
Dans price
Install Big Sleeves and O-Ring 89mm $900
Block Shafts holes - $40
Balance 4 cly- $132
Assemble Engine - $300
Polish Crank - $40
Bearings- $120
CP pistons 9 to 1 89mm - $550
Shipping & Handling , includes wooden Box - $130
Not bad at all if you ask me
I bought the Rod's Elsewhere and just sent them to him with ARP's too
here are some pics of the block
Dans price
Balance 4 cly- $132
Polish Crank - $40
Bearings- $120
everything looks top notch and i esp. like the attention to detail w/ the O-ring job.
the cp website doesnt list anything for the F22 although i may have overlooked it. what are some specs on yours other than bore size? stock wrist pin location, normal # of ring lands, type of rings used, piston weight, etc.
im very interested in some custom high comp. pistons and CP seems legit so far. EF-1 has the most useless search function(just like this site does) and for me its nearly impossible to use. a simple search for "F22" on EF-1.com left me w/ 0 matches found.
89mm is cutting it close on the bore and i would like to sqeeze another mm or so out if possible. i see from your block that Benson keeps the open deck design, where as Darton does not. must say that im quite surprised you left it open w/ such "thin" sleeves now.....
for EF-1.com users, whats the best way/forum to get some responses concerning custom 13:1+ CP brand pistons for the F?
Modified by kentucky accord at 12:41 AM 11/25/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Globalundrground »</TD></TR><TR><TD CLASS="quote">price break down
Dans price
awesome! thanks!!
just what i needed. hopefully i can send mine in this winter
btw how much did you pay for the crower rods?
also, what would taking out the balancer shaft out do?
Dans price
awesome! thanks!!
just what i needed. hopefully i can send mine in this winter btw how much did you pay for the crower rods?
Tommy_Gunns
Aug 22, 2002 07:15 PM
