to all eg with d16z6 & tranny guys
Old Nov 24, 2003 | 06:11 AM
Charlie Moua's Avatar
Default to all eg with d16z6 & tranny guys
with stock motor and ex/si d16z6 tranny what RPM are you at during 70mph?
i was driving a eg ex and when i was going 70mph it was only like at 2700rpms
did u get a dx/lx/vx/cx tranny?
Old Nov 24, 2003 | 06:22 AM
2000blackgsr's Avatar
Default Re: to all eg with d16z6 & tranny guys (Charlie Moua)
Check out http://home.cinci.rr.com/mistab0ne/tranny.html
You should be at 2650 at 60mph and 3533 at 80mph with an EX tranny.
However, with the inaccuracy of stock tachs, I think still could be an EX tranny.
Modified by 96coupe at 10:42 AM 11/24/2003
Old Nov 24, 2003 | 06:24 AM
jeremyEG's Avatar
70 should be in the 3k range. 2700 sonds like a dx tranny. a cx/vx tranny would only be at about 2300.
Old Nov 24, 2003 | 06:40 AM
twistd's Avatar
well i also think it depends what gear he's in.
Old Nov 24, 2003 | 06:45 AM
Default Re: (twistd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistd &raquo;</TD></TR><TR><TD CLASS="quote">well i also think it depends what gear he's in.</TD></TR></TABLE>
5th gear.
Old Nov 24, 2003 | 06:48 AM
Default Re: to all eg with d16z6 & tranny guys (96coupe)
P20/A000 is for DX/CX/VX
P20/B000 is for EX/Si
where can i find that tranny code?
Old Nov 24, 2003 | 06:53 AM
5thgencivic's Avatar
Right around the fill plug on the tranny. I think it's a little above it but I can't remember.
Old Nov 24, 2003 | 08:33 AM
Default Re: to all eg with d16z6 & tranny guys (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">Right around the fill plug on the tranny. I think it's a little above it but I can't remember.</TD></TR></TABLE>
anyone else confirm?
can i see it from the engine bay or do i have to get under the car?
Old Nov 24, 2003 | 08:40 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96coupe &raquo;</TD></TR><TR><TD CLASS="quote">.
Modified by 96coupe at 10:42 AM 11/24/2003</TD></TR></TABLE>
the tach is mostlikely way off....usually 10-15% if not more!
Old Nov 24, 2003 | 08:44 AM
jdmknight's Avatar
yea i was at around 3200 rpms..
Old Nov 24, 2003 | 10:02 AM
bump
Old Nov 25, 2003 | 02:43 AM
Mista Bone's Avatar
D Tranny Guru
tach and/or speedo is off.
DX tranny, 3000 rpm = 72 mph on the speedo MY car.........
real speed = 71.15 mph
2700 rpm in CX/VX tranny would be 80 mph.
http://nonsense.netfirms.com/speed.html
Old Nov 25, 2003 | 02:52 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
can i see it from the engine bay or do i have to get under the car?</TD></TR></TABLE>
A small mirror would make it easy to see.
Chiovnidca's Avatar
It also depends on the tire size.
Old Nov 25, 2003 | 03:04 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
It also depends on the tire size.</TD></TR></TABLE>
wrong there..........
The tranny/VSS/speedo will never know what size tire is on the car.
Old Nov 25, 2003 | 04:11 AM
Default Re: (Mista Bone)
is there a test you can do to test if the tack/speedo is getting correct about of amperage/volts?
Also where can i find that tranny code?
I though that the smaller tires you have the faster you accelerate but with less top speed due to the diameter of the rims/tires.
The car has 14 optional allow with some 195/55/14 on if that mattered.
Old Nov 25, 2003 | 05:07 AM
blackeg's Avatar
Default Re: (Charlie Moua)
70 mph in 5th puts me at like 2900rpm. 80 is at like 3400.
Old Nov 25, 2003 | 02:16 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
The tranny/VSS/speedo will never know what size tire is on the car.</TD></TR></TABLE>
Yep your right, it will affect the actual speed of the car though.
Old Nov 25, 2003 | 02:20 PM
Ricey McRicerton's Avatar
Just crawl up under the car and check. You should'nt have gotten into this whole car scene if you did'nt want to get a little dirty every now and then.
Old Nov 25, 2003 | 05:42 PM
ekb18cCivic's Avatar
The tranny/VSS/speedo will never know what size tire is on the car.</TD></TR></TABLE>haha i dont dare ques mistabone but isnt it true that if the tire size is wrongit will throw off the speedo by a few mph???
Old Nov 25, 2003 | 05:46 PM
jdmsiR20's Avatar
Default Re: to all eg with d16z6 & tranny guys (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Just crawl up under the car and check. You should'nt have gotten into this whole car scene if you did'nt want to get a little dirty every now and then. </TD></TR></TABLE>
yeah, easy as pie ... just check it out, good to know
Old Nov 25, 2003 | 06:22 PM
Jim Truett's Avatar
Default Re: (ekb18cCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic &raquo;</TD></TR><TR><TD CLASS="quote">haha i dont dare ques mistabone but isnt it true that if the tire size is wrongit will throw off the speedo by a few mph???</TD></TR></TABLE>
This is only true if you were to measure the speed with an external meter, like RADAR. It will not affect the speedo in relation to the tach.
CRXREFIC
Aug 7, 2009 10:19 AM
s1ngleslam
Oct 28, 2008 10:29 AM
EJ ITO
Sep 28, 2007 09:16 PM
GdmLaz
Jan 8, 2005 12:29 PM
IMOTEPHT94501
Jul 9, 2004 11:21 AM
