oversteer?
Old Nov 23, 2003 | 10:06 PM
yakitori's Avatar
Default oversteer?
anybody else having problems with TOO MUCH oversteer in their hatchback? mines is a 1995 it feels some what dangerous and is hard to control
Old Nov 23, 2003 | 10:40 PM
H22A EG6's Avatar
Default Re: oversteer? (yakitori)
never had a prob with over steer in a FF car
Old Nov 23, 2003 | 11:18 PM
yakitori's Avatar
Default Re: oversteer? (H22A EG6)
anyone else?
Old Nov 24, 2003 | 12:28 AM
VX's Avatar
VX
What's your suspension set-up?
Old Nov 24, 2003 | 12:34 AM
Feuerraeder's Avatar
Default Re: oversteer? (VX)
so much oversteer its a problem?
if you've managed to set the car up to do that, then you ought to know how to correct it. it's not easy getting an FF car to oversteer. explain the setup and situation a little better.
Old Nov 24, 2003 | 12:38 AM
yakitori's Avatar
Default Re: oversteer? (Feuerraeder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Feuerraeder &raquo;</TD></TR><TR><TD CLASS="quote">so much oversteer its a problem?
if you've managed to set the car up to do that, then you ought to know how to correct it. it's not easy getting an FF car to oversteer. explain the setup and situation a little better.</TD></TR></TABLE>
i have a 15mm rear sway bar stock 95 si front (??mm) koni shocks tanabe super down precedeo springs falken azenis 14"... I haven't really touched anything on the car besides putting on the shocks and the rear sway bar the shocks are all set to the softest setting..the rear of the car really comes out a lot and I have to keep the wheel straight a lot but with no lsd I can't really gas it. the falkens slide really easily esp down hill
Old Nov 24, 2003 | 12:47 AM
sounds like a technical problem somewhere else in the rear suspension...I have a 22mm rear sway and HR Sports..I can hardly get the rear out if i try, even with throttle lift.
perhaps your suspension is binding in the rear, or something else is restricting suspension travel. or maybe something's broken causing you too bottom out hard. does it seem to ride really rough in the rear compared to the front? a stiffer rear set up will cause oversteer, but never to the point of undrivability. my money is on something being broken. check it out or take it somewhere ASAP, it could be dangerous.
do keep us posted though.
Old Nov 24, 2003 | 12:48 AM
yakitori's Avatar
when I push the rear down with my hands it shows no resistance feels same as stock the front feels a bit stiffer than the rear
could it be my driving?
Old Nov 24, 2003 | 05:02 AM
Targa250R's Avatar
be professional
You'll need to get someone who knows what they're doing to adjust your suspension for you.
Also, do you have a habit of letting off the throttle in mid-turn?
Old Nov 24, 2003 | 05:08 AM
RickChew's Avatar
Default Re: oversteer? (Targa250R)
My friends 92 accord has major oversteer problems....its great!!
And yeah, most cars (though not my civic) are alot more likely to swing out the rear if you back off the throttle mid turn.
Rick
Old Nov 24, 2003 | 05:29 AM
jolt-tsp's Avatar
If you're getting oversteer then loosen the back and tighten the front if ya can.
Old Nov 24, 2003 | 06:28 AM
RyanEJ8's Avatar
Default Re: oversteer? (RickChew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickChew &raquo;</TD></TR><TR><TD CLASS="quote">
Rick </TD></TR></TABLE>
My Civic doesn't swing out if I back off the throttle mid turn, either. I thought this was more of a problem with rear wheel drive and understeer.
Old Nov 24, 2003 | 06:30 AM
Targa250R's Avatar
be professional
Default Re: oversteer? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
My Civic doesn't swing out if I back off the throttle mid turn, either.</TD></TR></TABLE>
Must be pretty slow then
Old Nov 24, 2003 | 06:34 AM
Mike_C's Avatar
There is no way your car oversteers w/ that setup if everything is installed properly. Check your bushings and everything, you might be getting some binding that isn't allow the rear to compress?
Old Nov 24, 2003 | 06:44 AM
Pancake Titties's Avatar
Learn to drive, oversteer is a gift from the gods. Understeer is for pussies.
Old Nov 24, 2003 | 06:50 AM
Carlo's Avatar
Default Re: oversteer? (Pancake *******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pancake ******* &raquo;</TD></TR><TR><TD CLASS="quote">Learn to drive, oversteer is a gift from the gods. Understeer is for pussies.</TD></TR></TABLE>
Calm down hot shot.
Old Nov 24, 2003 | 06:51 AM
Targa250R's Avatar
be professional
Yeah, whatever.
Old Nov 24, 2003 | 06:56 AM
Phrack65's Avatar
Ok, flame me if I'm completly off track here, but have you tried altering your tire pressures? The only time I ever oversteered in my car was when I left the rear tires at the psi thats meant for carrying heavy loads. Bear in mind that this was completely stock with crappy tires tho.
Old Nov 24, 2003 | 07:22 AM
jolt-tsp's Avatar
Default Re: oversteer? (Phrack65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phrack65 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, flame me if I'm completly off track here, but have you tried altering your tire pressures? The only time I ever oversteered in my car was when I left the rear tires at the psi thats meant for carrying heavy loads. Bear in mind that this was completely stock with crappy tires tho.</TD></TR></TABLE>
Thats a good call to, first thing to check
Old Nov 24, 2003 | 07:49 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Must be pretty slow then </TD></TR></TABLE>
No it just handles better than yours.
Old Nov 24, 2003 | 09:25 AM
Targa250R's Avatar
be professional
No it just handles better than yours. </TD></TR></TABLE>
Nah, yours just plows like an understeering pig while mine rotates like it should
But seriously, go to an autocross event and lift off the throttle and/or slam on the brakes in a hard corner. Your rear end will rotate. This is a characteristic of the FF drivetrain layout. This is why advanced FF autocrossers use left-foot braking.
Old Nov 24, 2003 | 09:27 AM
Mike_C's Avatar
This is a characteristic of the FF drivetrain layout. </TD></TR></TABLE>
It's a characteristic of all drivetrains, simple physics. If you unload the rear it will want to go in a straight line (rotate).
Old Nov 24, 2003 | 09:37 AM
Targa250R's Avatar
be professional
Default Re: oversteer? (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 &raquo;</TD></TR><TR><TD CLASS="quote">
It's a characteristic of all drivetrains, simple physics. If you unload the rear it will want to go in a straight line (rotate).</TD></TR></TABLE>
Yep.
I've seen many people "0wn3d" by lift-throttle oversteer. I'm sure you've seen many more.
Old Nov 24, 2003 | 11:58 AM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">But seriously, go to an autocross event and lift off the throttle and/or slam on the brakes in a hard corner. Your rear end will rotate. This is a characteristic of the FF drivetrain layout. This is why advanced FF autocrossers use left-foot braking.</TD></TR></TABLE>
yeah thats right. that happend to me at autox when i picked up off the throttle. my back end kicked out a few times with a stock suspension setup.
Old Nov 24, 2003 | 01:45 PM
Default Re: oversteer? (jwn7)
isnt that a scandinavian flick?
