hondata, and b16a1
Old Nov 23, 2003 | 08:47 PM
jaydmcrx's Avatar
Default hondata, and b16a1
In order to use a hondata ecu, i have to convert to obd1. But i am using a b16a1 head? So do i have to just use the a2 distributor, and wire in the plug to make it work? and use the obd0 to 0bd1 harness for the ecu? thanks. I need to know this before i get too involved with my project
Old Nov 24, 2003 | 01:05 AM
Kwuaymaikrup's Avatar
Default Re: hondata, and b16a1 (jaydmcrx)
I assume that your car is non-OBD. You have 2 options. One...buy a non-OBD PR3 ecu and chip it for Hondata. Two...convert to OBD1 ie, dist, ecu, injectors...etc. I went with the non-OBD PR3ecu. There is one in classifeds right now. GL
-Ryan
Old Nov 24, 2003 | 09:08 AM
jaydmcrx's Avatar
yah i think what im gonna do is get an obd1 head. like a gsr or b16a2 and completely convert to obd1. i am using a b20 block anyways. so i think it will work out in the end
Old Nov 24, 2003 | 09:12 AM
PHiZ's Avatar
Default Re: hondata, and b16a1 (Kwuaymaikrup)
Swap the dizzy(re pin the distributor , convert to 4 wire 02 sensor, I think you can keep the injectors if you leave the resistor box inline.
There are some links in this thread that offer help:
https://honda-tech.com/zerothread?id=685646
-PHiZ
Old Nov 24, 2003 | 10:22 AM
jaydmcrx's Avatar
thanks guys
gian_ed7b16a1
Feb 12, 2016 04:09 AM
gsr_88_crx
Sep 19, 2008 07:32 PM
R6E6I6D
Jul 24, 2005 06:08 AM
dalepatters
Feb 14, 2003 02:48 PM
C4wrx
Aug 9, 2002 12:00 AM
