GSR intake manifold question in EG
ok I heard that if i run a GSR intake manifold I'll have to switch back to a single cam throttle cable. (I had a b16a head before so I switched my throttle cable to a b16a). Also, if I use a Skunk2 IM for my GSR head what throttle cable would I use then? I know that the GSR and B16A brackets for the throttle cables are different also.... im confused.
do you have a picture or what it looks like? Also.. if i use the skunk2 manifold.. do you think the b16a throttle cable and bracket will work along with a b16a or single cam throttle rotor? i know the gsr throttle rotor is complete different and spins the opposite direction...
well i ran into sorta the same problem. I had a bored out gsr throttle body and got a skunk2im so instead of getting a new bracket and linkage i just cut the gsr throttle cable bracket and rewelded it so it works. but if you wanna run it the other way with like a b16 or whatever tb then you would use a integra TypeR cable and bracket from acura which i believe is like around $25
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECoupe »</TD></TR><TR><TD CLASS="quote">do you have a picture or what it looks like? Also.. if i use the skunk2 manifold.. do you think the b16a throttle cable and bracket will work along with a b16a or single cam throttle rotor? i know the gsr throttle rotor is complete different and spins the opposite direction...</TD></TR></TABLE>
dont have any pics...but i did use the cam throttle from a d16z6 throttle body
TurboIntegra
Jul 21, 2006 03:25 AM
vtec25
Jun 13, 2006 02:29 PM
crxowner
May 18, 2006 07:39 AM
