d16 timing belt tensioning question.
Old Nov 23, 2003 | 07:19 PM
aerogant's Avatar
Default d16 timing belt tensioning question.
How often does a timing belt need to be tensioned? Is it a case of just adjusting it when replacing and not touching it again? Should the belt be very tight, or should it have play like an alternator belt? Thanks for your time.
Old Nov 23, 2003 | 07:34 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: d16 timing belt tensioning question. (aerogant)
just once, the leave it. Loosen the tensioner, then rotate the engine so the cam gear moves 3-4 teeth on the belt. This usually tightens the belt enough.
Just use sense....it doesn't need to be crazy tight, but it can't be sloppy either
dleccord
Apr 13, 2020 08:03 AM
airikkCRX
Apr 2, 2010 08:29 AM
djviet2000
Apr 6, 2008 10:55 PM
JDMtype Eg6
Feb 18, 2007 05:45 AM
blayzenazn
Feb 18, 2002 07:51 AM
