radiator leak
Old Nov 23, 2003 | 06:09 PM
social_control's Avatar
Default radiator leak
what up h/t...i gotta radiator leak but don't know where it's coming from. here are the details...noticed a week or two ago when i was under the car that some radiator fluid had dripped on my shirt, started looking around to find my radiator resevar (check that spelling) was near empty, put some antifreeze in there, week later below the max line again, heard something about distilled water so i put that in there, once again it leaked out to, i looked under the hood, right under the fans that are in the front of the engine i noticed antifreeze had leaked and settled on the plastic piece (right below the fans)....so i know i have a leak, just don't know where. i have changed the upper and lower radiator hoses, so i know it can't be those...anyone had this similar problem or know anything i should check out?
Old Nov 23, 2003 | 06:38 PM
timmy8151's Avatar
Default Re: radiator leak (Seprioth64)
Try checking the plasctic top of the radiator. OEM radiators usually crack at around 100K miles.
Old Nov 23, 2003 | 07:16 PM
Default Re: radiator leak (timmy8151)
the piece that unscrews or the actual container piece...that holds the fluid?
Old Nov 23, 2003 | 07:27 PM
D.CACO's Avatar
sometimes a very small piece of debris(rock) can fly into a radiator and make a very very small leak in the radiator core itself... unlikely but worth investigating. Most likely, the to top or bottom plastic, or a small seal leak maybe.
Sounds like a needle in a haystack, eh?
tommyt761
Oct 12, 2006 01:00 PM
Dooley
Apr 15, 2006 06:55 PM
FD3S
Dec 15, 2005 08:37 AM
vtecmw
Dec 5, 2005 09:44 AM
Audio28
Dec 29, 2002 04:44 PM
