i heard of gst/gsx 450cc injectors will eit in hondas...how does this work?
They work fine, you need the resistor box out of an older integra or civic/crx because they are peak and hold injectors. (assuming you have a newer motor that uses saturated injectors).
Dustin
Dustin
peak and hold are low impedence so you need resistors inline or you will fry the injector drivers in the ECU. They inject fuel the same way.
Dustin
Dustin
stockhatch91
Nov 22, 2004 03:59 PM
Rod.
Sep 19, 2003 01:26 PM
