Poor throttle response after timing belt and fuel filter install
Old Nov 23, 2003 | 03:32 PM
Wide Open Throttle's Avatar
Default Poor throttle response after timing belt and fuel filter install
We just did the above maintenance on my Integra and now the engine response is very poor. When you press down on the throttle in any gear it takes 2-3 seconds for the engine to rev up properly. Its like you are taking off from a stop in 3rd gear or something.
I heard that it could be the timing belt not tensioned properly or maybe a problem with the car not getting enough fuel through the filter.
Any help would be appreciated!
Old Nov 23, 2003 | 04:46 PM
Dropspeed's Avatar
Default Re: Poor throttle response after timing belt and fuel filter install (Wide Open Throttle)
I would bet that your timing belt is off a tooth (cams and crank are not lined up)
Pull the valve cover back off and rotate the belt until the crank pulley is at the TDC mark and then make sure the cam gear marks line up with the marks on the plastic cover horizontally.
Mattj
Modified by Dropspeed at 9:20 AM 12/5/2003
Old Nov 23, 2003 | 05:32 PM
b19coupe's Avatar
Default Re: Poor throttle response after timing belt and fuel filter install (Dropspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">I would bet that your timing belt is off a tooth (cams and crank are not lined up) </TD></TR></TABLE>
I second that.
Old Nov 23, 2003 | 05:41 PM
98itR484's Avatar
Mattj</TD></TR></TABLE>
i agree also. Check the crank pulley, place it at TDC and check the gears again....*echo...echo*
redright9
Feb 7, 2011 11:26 AM
Seedc2
Mar 22, 2005 04:53 PM
Civiclx
Nov 30, 2003 01:52 PM
nolimits
Jul 31, 2003 11:26 AM
xpurespeedx
Apr 15, 2003 10:12 AM
