Wiring 97 integra factory deck to amp????!!!!!?!!?!?!?!?!?
Old Nov 23, 2003 | 01:45 PM
Pino_WM's Avatar
Default Wiring 97 integra factory deck to amp????!!!!!?!!?!?!?!?!?
i have no idea what to do....i have no money right now to buy and aftermarket head unit and was wondering what i need to do. I did a bit of research and i found out i need to buy a line level adaptor or line output converter. If some could help explain how i would go about doing this it would be greatly appreicated.
Thanks a lot
Old Nov 23, 2003 | 08:54 PM
vigor5spd's Avatar
Default Re: Wiring 97 integra factory deck to amp????!!!!!?!!?!?!?!?!? (Pino_WM)
You need a line level to RCA converter. Walmart sells them for like 10 bucks if I recall correctly. Then you will need to decide if you want to tap into the front or rear channel of the stock deck.
Old Nov 24, 2003 | 08:51 AM
Pino_WM's Avatar
Default Re: Wiring 97 integra factory deck to amp????!!!!!?!!?!?!?!?!? (vigor5spd)
Thanks man.......
nsxxtreme
Audio / Security / Video
18
Aug 26, 2011 08:29 AM
Sorcin
May 17, 2010 09:07 PM
MestizoRacer310
Nov 30, 2006 06:08 AM
SonicGSR
Jun 1, 2002 05:12 PM
archmage
Nov 28, 2001 09:08 PM
