Drove Thru High Water
Old Nov 23, 2003 | 07:32 AM
TXaccord's Avatar
Default Drove Thru High Water
Last week I tried to drive my '90 Accord thru high water and now it won't start. Does anyone have any post-flood tips. The car turns over and sounds like it's going to start...but never does. Any way to tell if water got in the engine?
Thanks in advance.
Old Nov 23, 2003 | 08:25 AM
Kamin's Avatar
Default Re: Drove Thru High Water (TXaccord)
compression test it, while the spark plugs are out dry them off. if your compression numbers are normal reinstall the spark plugs and pray
you probably hydrolocked the motor.
DONT DRIVE THROUGH HIGH WATER
Old Nov 23, 2003 | 12:37 PM
Perfectionist's Avatar
How "high" was the water? Did you get through it before it died or did it sit and soak? Is the carpet wet? Was the exhaust under water? Do you have a CAI?
Look in the air filter housing for signs of water. If it's wet, you may have sucked water into the engine.
Old Nov 23, 2003 | 01:20 PM
TXaccord's Avatar
Default Re: Drove Thru High Water (Perfectionist)
The water was lower then my door, so nothing got wet inside. I don't think the exhaust was under water, but I did get hit by a "wave" in the front. Which was at the same time the car died. I turned off into a parking lot as it died and pushed it to high ground.
The air filter was wet, but no water in the housing.
What is a CAI?
Old Nov 23, 2003 | 01:37 PM
PTL's Avatar
PTL
(CAI)= Cold Air Intake
i think you have water in your motor seen your air filter wet
Old Nov 23, 2003 | 04:15 PM
dan89crxsi's Avatar
Default Re: Drove Thru High Water (PTL)
take off the distributor cap and blow it dry with air, take out and clean spark plugs
Kamin's Avatar
Default Re: Drove Thru High Water (dan89crxsi)
how would the internals of the distributor be wet from driving through a puddle?
Old Nov 23, 2003 | 04:35 PM
civicvtec3's Avatar
Hey I just want to say that I did the same thing once and I ended up snaping to connecting rods. So I would dififinitely do a compression test to make sur that you did not break any thing internally.
good luck
Old Nov 23, 2003 | 07:22 PM
lsvtec hatch05's Avatar
1st clue, don't drive through high water
Old Nov 24, 2003 | 09:19 AM
doublejz's Avatar
https://honda-tech.com/zerothread?id=686561
Old Nov 24, 2003 | 12:43 PM
kpt4321's Avatar
If yours turns over, it's probably ok.
Check the compression, and if that checks out, then it's simply a matter of drying and fixing whatever got wet.
For experimental purposes, my friends and I squirted a garden hose into a D15 until it died. We cranked it for a few seconds (~10) and it started back up. Several times in a row.
Old Nov 24, 2003 | 01:10 PM
Kamin's Avatar
Default Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">If yours turns over, it's probably ok.
thats not true. i had a hydrolocked GSR that i worked on that cranked fine but had 30psi compression in cyl #2 because of water.
and you cant just stuff a garden hose down the intake and expect it to hydrolock, thats alot of water, too much in fact.
Old Nov 24, 2003 | 02:36 PM
kpt4321's Avatar
IF THE COMPRESSION CHECKS OUT.
30 psi certainly isn't "checking out."
Old Nov 24, 2003 | 03:55 PM
Kamin's Avatar
IF THE MOTOR TURNS OVER YOU ARE PROBABLY OK
thats what i was comment on.
Old Nov 24, 2003 | 04:23 PM
dan89crxsi's Avatar
Default Re: (Kamin)
I dorve in some heavy rains (hurricane) and my car died and I tried to start it and it wouldnt start so I had it towed and the next day I went to go look at it and there was a hole in the front and back of my crankcase....... I snapped a rod and blew a hole out the block but mine would definately not turn over so I would most certainly go with the compression test first
Old Nov 24, 2003 | 07:04 PM
Bailhatch's Avatar
Default Re: (dan89crxsi)
if it's quiet while your cranking your probably just looking at an electrical problem.
the_tensl
Aug 13, 2014 11:09 PM
jscrib
Sep 26, 2010 04:42 PM
K20Death
Apr 30, 2006 02:25 PM
leftymo
Dec 28, 2004 12:02 PM
ck279
Jun 7, 2002 07:23 AM
