suckin down gas like a mustang
Old Nov 23, 2003 | 06:14 AM
JRadd8's Avatar
Default suckin down gas like a mustang
My 97 EX civic just started suckin down gas (200 miles per tank) for no apparent reason. I didnt change anything recently, and i can smell the unburnt fuel comin out the back. I have 85 thou. miles. Any ideas?
Old Nov 23, 2003 | 06:16 AM
The Internet Tough Guy's Avatar
Default Re: suckin down gas like a mustang (JRadd8)
check your oxygen sensor
Old Nov 23, 2003 | 06:22 AM
JRadd8's Avatar
Default Re: suckin down gas like a mustang (jwn7)
i thought the o2 sensors on civ's were good for 100,000 miles? Man they are like 300 bux a piece too... i was afraid of that. Im gonna swap out the TPS and external coil, too.
Old Nov 23, 2003 | 08:03 AM
Doctor CorteZ's Avatar
whats the reference voltage on the O2 at WOT ? and idle ?
I highly doubt a new TPS or external coil is going to fix your problem...
Old Nov 23, 2003 | 08:07 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRadd8 &raquo;</TD></TR><TR><TD CLASS="quote">i thought the o2 sensors on civ's were good for 100,000 miles? Man they are like 300 bux a piece too... i was afraid of that. Im gonna swap out the TPS and external coil, too.</TD></TR></TABLE>
go to autozone get a bosch universal for your honda, about 70$
DO NOT TOUCH THE TPS SENSOR, you would have other driveability problems if it was your TPS and you are just gonna cause needless headaches trying to recalibrate the new one.
o2 sensors dont usually last to 100,000 miles.
Old Nov 23, 2003 | 08:51 AM
Chiovnidca's Avatar
Default Re: suckin down gas like a mustang (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
o2 sensors dont usually last to 100,000 miles.</TD></TR></TABLE>
Most of them do.
Old Nov 23, 2003 | 09:07 AM
mad_96civic's Avatar
recet your ecu. (enjine controll unit)
to do this disconect your battery for about 20 min, and then start it and let it warm up on its own with no reving.
and when you drive just dont take it past 3k f(or a long period of time like 2-3 weeks )
trust me itll work
Old Nov 23, 2003 | 09:27 AM
Kamin's Avatar
Default Re: (mad_96civic)
2-3 weeks?! dude no!
it takes 20 seconds to reset the ecu, pull ecu fuse wait 20 seconds, replace ecu fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mad_96civic &raquo;</TD></TR><TR><TD CLASS="quote">trust me itll work</TD></TR></TABLE>
um , yeah.
and its "engine" , no J.
Old Nov 23, 2003 | 09:41 AM
SLeePeR012's Avatar
And it's "reset", no C
Ok first off don't listen to this guy.
Second do the common thing and check your plugs. Make sure the engine is cold.
Do a search you can find out what kind of readings your getting.
Or you can use ClubSi's.
http://www.clubsi.com/spark_plug_tech.shtml
Old Nov 23, 2003 | 11:39 AM
Chiovnidca's Avatar
LMAO Reminds me of the saddam hussein character on Southpark.
Old Nov 23, 2003 | 01:48 PM
Caveman74's Avatar
I replaced mine about two months ago W/ NGT, and I dont think it gets any better mileage. actully I'm thinking worse. I pulled my ECU fuse yesterday, so I'll have to see what thr results are.
Old Nov 23, 2003 | 01:56 PM
Chiovnidca's Avatar
Default Re: suckin down gas like a mustang (Caveman74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 &raquo;</TD></TR><TR><TD CLASS="quote">I replaced mine about two months ago W/ NGT, and I dont think it gets any better mileage. actully I'm thinking worse. I pulled my ECU fuse yesterday, so I'll have to see what thr results are.</TD></TR></TABLE>
There are other causes of poor fuel mileage than o2 sensors.
Old Nov 23, 2003 | 02:42 PM
nY's FiNeSt's Avatar
Default Re: suckin down gas like a mustang (Chiovnidca)
can't bad spark plugs cause poor gas milage also? someone confirm please...
Old Nov 23, 2003 | 03:05 PM
RangerDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mad_96civic &raquo;</TD></TR><TR><TD CLASS="quote">recet your ecu. (enjine controll unit)
Old Nov 23, 2003 | 05:13 PM
Chiovnidca's Avatar
Default Re: suckin down gas like a mustang (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt &raquo;</TD></TR><TR><TD CLASS="quote">can't bad spark plugs cause poor gas milage also? someone confirm please...</TD></TR></TABLE>
yes
ruffrhyder
Sep 23, 2008 08:15 AM
Mr.Luder
Aug 11, 2007 04:13 PM
HCJDM1
11
Apr 5, 2007 09:00 AM
happy_guy
Sep 20, 2005 12:58 PM
turbo Si
Aug 10, 2004 05:35 PM
