94 civic ex with H22 swap
Old Nov 23, 2003 | 04:20 AM
rob d's Avatar
Default 94 civic ex with H22 swap
Needs paint and its rolling on 14" steel. It has new front and rear bumpers, 2 fenders and hood. EK side skirts. It has power everything including PS. No AC. I even hooked up the EGR ang its working. Amber interior lights. Autometer oil and af gauge. shift light. Full gauge pod a-piller holder. Center audio console and arm rest. Car cover. $6000
The spec:
94 civic EX 14xxxx miles
93 jdm h22 40xxx miles
New distributor
injectors cleaned by rc
new clutch master
new duel core rad
rear disc swap
new 1" brake master
4040 prop valve
rebuilt front and rear calipers
ss brake lines
brembo drilled and sloted disc
aem brake pads
raxle axle (90-93 teg) accord half shaft with new bearing
hasport mounts
tokiko ill. shocks
ground control coil over 400lbs front and 275 rear
tanabe g madalion exhaust with test pipe.
p13 ecu chipped by katman
Modified by rob d at 6:22 PM 11/30/2003
Old Nov 24, 2003 | 03:45 AM
rob d's Avatar
Default Re: 94 civic ex with H22 swap (rob d)
dadsvtechonda
Apr 21, 2008 03:01 PM
94c1v1cex
14
Jul 20, 2007 02:07 PM
wilkerson05
Suspension & Brakes
Oct 16, 2005 06:00 PM
Optiks.
Nov 10, 2002 01:38 PM
kreush33
Oct 7, 2002 11:21 AM
