is there a way to add a tach gauge cluster in a civic dx/cx?
Old Nov 23, 2003 | 03:14 AM
ImolaS54's Avatar
Default is there a way to add a tach gauge cluster in a civic dx/cx?
i am guessing it would be from a si on the HB.
Thanks
Old Nov 23, 2003 | 03:24 AM
ekx4's Avatar
99-00 si coupes good swap overs.
Old Nov 23, 2003 | 04:47 AM
pROjECt_D-sOL's Avatar
Default Re: (ek9y)
u can also use the cluster from a 92-95 civic ex or the hatchback vx's i think
Old Nov 23, 2003 | 05:54 AM
E.G.6's Avatar
Default Re: (pROjECt_D-sOL)
You can get the tach cluster on the EX, Si and the VX.
Si/EX will register redline at 7200rpm while the VX registers redline at 6800rpm.
Old Nov 23, 2003 | 06:10 AM
DX Hybridizer's Avatar
Default Re: is there a way to add a tach gauge cluster in a civic dx/cx? (ImolaS54)
What year civic are we talking about here? Yes you can swap oem clusters from a model that did have one.
92-95 = lx/vx/ex/si - sometimes dx (optional)
96-00 = ex/si/ help me out guys what else?
Old Nov 23, 2003 | 06:12 AM
Drews Bitch's Avatar
Default Re: is there a way to add a tach gauge cluster in a civic dx/cx? (DX Hybridizer)
https://honda-tech.com/zerothread?id=685517
i'm selling mine right now
Old Nov 23, 2003 | 06:29 AM
ImolaS54's Avatar
would this be like plug and play? or do i need to run additional wiring?
it would be for a 96+ civic HB
thanks
Old Nov 23, 2003 | 07:08 AM
i belive it would be plug n play but i don't know for sure
Old Nov 23, 2003 | 07:18 AM
boostedbastard's Avatar
Default Re: is there a way to add a tach gauge cluster in a civic dx/cx? (shepworldwide)
if your car is a 92-95 then any cluster from a 92-95 will plug up and work without any additional wiring. If your car is a 96-00 then one from the same model will work. If you try to use a cluster from a 99 in a 92-95 them there may be some additional wiring involved.
Old Nov 23, 2003 | 07:31 AM
Skip01's Avatar
I have a quick question kinda on-topic,I have had me EX gauge cluster for over a year now no probelms,i recently took it out to paint the bulbs Amber,and went to put it back in and plugged every thing up,even this yellow clipped harness that i don't remember pluggin in the last time,anyways i started it up and looked at the cluster,worked normally.Then went to turn off my car and it didn't turn off and I had the key in my hand.Crazy,I went back and unplugged the yellow one and everything was normal.What the hell was that,what would be the purpose of that?I was nervous as hell,hahaha.peace.
Old Nov 23, 2003 | 08:27 AM
Mr Miyagi's Avatar
It is plug and play, i have an ex cluster in my 97 dx hb and it took all of two minutes to install
nofearacer
Mar 12, 2009 06:19 PM
jjs316
Mar 29, 2005 09:57 PM
duncan
15
Mar 12, 2003 08:12 AM
JohnnyEF
Jul 16, 2002 02:54 PM
