new jrsc times
finally ran my car at the track, still having bad traction problems. if i don't lift off the gas, the tires will spin all through 2nd. i'm using nitto 555r's, time for some slicks.
2.03 60ft
8.40 @ 87.89 1/8
12.86 @ 110.51 1/4
2.03 60ft
8.40 @ 87.89 1/8
12.86 @ 110.51 1/4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deez92 »</TD></TR><TR><TD CLASS="quote">finally ran my car at the track, still having bad traction problems. if i don't lift off the gas, the tires will spin all through 2nd. i'm using nitto 555r's, time for some slicks.
2.03 60ft
8.40 @ 87.89 1/8
12.86 @ 110.51 1/4</TD></TR></TABLE>
Hi deez92; what size slicks are you looking for ?
John@M&H-Hashim's
good time. I would suggest 22x8's for power under 260whp with around 2600lb car. For over 260whp I would suggest 23.5x8's.
I ran 12.5@114 with 22x8's with 2.29 60ft and spinning the slicks down the track. Over powered the slicks with 285whp, 2400lbs car with no nitrous, just charger.
I could hardly imagine times that good on Drag Radials with a JRSC car. Traction is just such a pain with the supercharger.
60 ft. on 555'r
1/8
1/4 mile & Mph
To you.
Maybe try some M&H 22 or 23s X 8 X 13 on lensos?
60 ft. on 555'r
1/8
1/4 mile & Mph
To you.Maybe try some M&H 22 or 23s X 8 X 13 on lensos?
24.5 x 8 x 13s would rock out , switch over to a 15 lb pully and start going 115- 117 mph and you can rock out with maybe a low low 12 or hopefully a high 11 with great traction.
awesome mph for the 10 lb kit
Nice times bro, glad to see the SC boys are still around.
Im right on your tail with my B16. Hpe to be faster next year with better tires.
I ran my bset (see sig) with tired BFG drag radials in some nice heat.
Best trap of the year was in Texassss at 114 also. Keep up the good work.
114mph man i bet that felt nice, hopefully i can get that fast. and yes thats pretty much my mods, minus the camgears, apex n1, and a cone filter. this is also my daily driver, still has a/c. thanks for all the kind words again guys.
ATgrills.com
Aug 23, 2003 05:02 PM
