95 civic with b16a2 swap throttle cable help? hose
Old Nov 22, 2003 | 09:36 PM
runitup's Avatar
Default 95 civic with b16a2 swap throttle cable help? hose
I need to know what throttle cable to use with the swap. Is it possible and can i use the one from the car. Or do I need to get the b series one. and what lower radiator hose do i use--the dol sol dohc vtec one does not fit the engine..
Old Nov 22, 2003 | 10:22 PM
eyeamvic's Avatar
I believe the old throttle body cable should work on the b16. And hows is the lower radiator hose not fitting? What's the problem you're getting with it. Should fit, maybe just having trouble getting it on.
Old Nov 22, 2003 | 10:35 PM
runitup's Avatar
Default Re: (eyeamvic)
the throttle cable fits on the tb but the throttle cable bracket is different, they are in different places, so they cable it not tight-how do i fix this and the lower radiator hose seems to small. I tryed a couple of times to squeeze in on, but it still didn;t go on. I hose looks pretty thin compared to the stock ex one.
Old Nov 23, 2003 | 08:31 AM
C M S's Avatar
Default Re: 95 civic with b16a2 swap throttle cable help? hose (b16v)
I did the same swap in my 92 hatch. i used a del sol throttle cable and bracket. Also used a del sol lower hose and a universal 16" upper hose. Worked perfect, fit like OEM. Good luck!!!!
Old Nov 27, 2003 | 12:16 PM
Cynical 1's Avatar
Haha! Try a goddamned search!
devney
Aug 3, 2007 08:39 PM
sLoWrAcEr
Mar 5, 2005 08:58 PM
mrbsponge
11
Feb 3, 2004 04:03 PM
runitup
Dec 4, 2003 10:27 AM
