95 civic with b16a2 swap throttle cable help? hose
I need to know what throttle cable to use with the swap. Is it possible and can i use the one from the car. Or do I need to get the b series one. and what lower radiator hose do i use--the dol sol dohc vtec one does not fit the engine..
Get either a DOHC del sol one. Or easier to find is any acura integra LS cable both will work fine. Dealer there like 20 something bucks.
You can use the hoses from a 99 si as well as the dohc del sol ones. I have two brand new upper and lower rad hoses that you need unused from honda if you would like to buy them. PM me.
These questions could have been answered by a search in the hybrid area. Check that area out you can learn all the little quirks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by woodaytek »</TD></TR><TR><TD CLASS="quote">hey, does it matter which ls cable to use? will the 90-93 ones work or not</TD></TR></TABLE>
I used a Type R throttle cable. Was like $20 new.
I've got the same swap in the same car. Just spend $10 and got to jdmshit.com and order the modified throttle cable bracket, their shipping is pretty good too.
runitup
Nov 27, 2003 12:16 PM
