Type-R Cams!
Old Nov 22, 2003 | 08:25 PM
rocket256's Avatar
Default Type-R Cams!
Are Civic Type-R cams ok for boost or are they have a to aggressive profile for boost? Anyone out there with them boosting and have no problems?
Old Nov 22, 2003 | 10:08 PM
earl's Avatar
Default Re: Type-R Cams! (rocket256)
I think they are a fine cam to use with a turbo...nothing bigger, however.
Old Nov 22, 2003 | 10:21 PM
rocket256's Avatar
can anyone else help me out!
Old Nov 22, 2003 | 11:52 PM
ekb18c's Avatar
type r cams are good for turbo cars.
Old Nov 23, 2003 | 01:22 AM
boredracer408's Avatar
I'd stick with GSR cams.
Old Nov 23, 2003 | 04:44 AM
Jay J's Avatar
Prince of Zamunda
Default Re: Type-R Cams! (boredracer408)
GSR or B16's from the del sol are good
Old Nov 23, 2003 | 06:22 AM
patdemps's Avatar
Default Re: Type-R Cams! (neuspeed)
Its been discussed many times. You may find more info in a search. But from what I understand GSR cams are better and easier to tune. Now if you can tune the overlap effectively, then it will all work out.
why not just sell them, buy some gsr cams and have yourself with left over money (i've got gsr cams with 9k on them, if your interested. looking for 80 shipped, includes stock cam gears.)
Old Dec 25, 2003 | 07:01 PM
rocket256's Avatar
Default Re: Type-R Cams! (patdemps)
ttt
now itr cams have been done but what about ctr cams? anyone!
Old Dec 25, 2003 | 07:07 PM
Unsung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">ttt
now itr cams have been done but what about ctr cams? anyone!</TD></TR></TABLE>
NEARLY the same cam. The results would be identical. I'll be running CTR cams with boost.
Old Dec 25, 2003 | 07:19 PM
havalilsi's Avatar
Default Re: Type-R Cams! (Unsung EM1)
ctr cams will give more flow on the top end, at least so says the fellows at import builders.
Old Dec 25, 2003 | 07:30 PM
rocket256's Avatar
Default Re: Type-R Cams! (havalilsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havalilsi &raquo;</TD></TR><TR><TD CLASS="quote">ctr cams will give more flow on the top end, at least so says the fellows at import builders.</TD></TR></TABLE>
that is good because I have both. A set of GSR and a brand new set of ctr cams. Also Im trying to make sure before I blow some $h!t up.
jksmith
Nov 3, 2008 05:52 PM
wearyfurball
16
Feb 19, 2008 08:54 AM
99B16Si
Apr 10, 2006 04:28 AM
JsNA99si
Mar 12, 2004 10:08 PM
SIReg9
Aug 13, 2003 03:18 PM
