maximum cam advance/retard with toda b's
Old Sep 13, 2001 | 04:18 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default maximum cam advance/retard with toda b's
hey all. i need a little tuning advice for my next dyno run. does anyone know the maximum i can advance/retard a set of toda b's in a stock b18c5 with just a mugen 2 layer headgasket? i just don't want to have any surprises (clank!) when i go to the dyno next week. i was thinking 4 degrees max. anyone have any recommendations? thanks for any help.
Old Sep 13, 2001 | 05:14 PM
Lip's Avatar
Lip
Default Re: maximum cam advance/retard with toda b's (rodney)
I never had to go beyond 2degrees either way with my old spec B's that had a 2 layer head gasket and 15thou head mill. hth
Old Sep 13, 2001 | 05:21 PM
Incognito's Avatar
Default Re: maximum cam advance/retard with toda b's (Lip)
My head is decked 20 thousandths, with stock head gasket. Cams are both advanced significanly... on AEM cam gears, 1 cam is advanced about 7 marks (14 degrees), and the other one a little less.
Old Sep 13, 2001 | 06:26 PM
98R-641's Avatar
Sorry, an unreleated question...
What spark plug gap are people using with spec B cams?
Are there a big difference on the gap?
thanks
Old Sep 14, 2001 | 02:18 AM
mafay2's Avatar
New User
Default Re: maximum cam advance/retard with toda b's (98R-641)
I tried +3,-1 setting on the new TODA cam gear with Spoon 2 layer headgasket with no problem!!
Actually I went as far as +5 on the intake cam gear at first, because I misunderstand the instruction for the cam gear!! Lucky me, nothing went wrong!!
Old Sep 14, 2001 | 04:12 AM
B18CXr's Avatar
which gears you using?
Old Sep 14, 2001 | 05:16 AM
Rodney's Avatar
Default Re: maximum cam advance/retard with toda b's (B18CXr)
setup is as follows: Toda spec b's,Toda cam gears (2nd gen), Toda springs, portflow retainers, and a stock b18c5 bottom end. i have had no experience tuning on the dyno, but i am a fairly competent mechanic. i am going to go within the next few weeks. also, it is my understanding to tune the air fuel ratio to 12.8 to 13.3 across the board. anyone have any thoughts on this? right now i can only get a ballpark air fuel ratio change due to the fact that i have only a adjustable fuel pressyre regulator. before everyone tells me to get a vafc or similar fuel tuning device, i plan on getting my ecu rom tuned on the dyno at the beginning of next season. i just want to get it running decent now. it is just "slapped" together at the moment. thanks all.
Old Sep 14, 2001 | 09:36 AM
B18CXr's Avatar
you can max those gears + or - with that setup.......no contact!!
Old Sep 14, 2001 | 09:42 AM
Lip's Avatar
Lip
your probably right...but i bet his settings don't need to be maxed either way. if there is no dyno...its gtech and track for you rod knee boy
Old Sep 14, 2001 | 09:43 AM
B18CXr's Avatar
agreeded.
Old Sep 14, 2001 | 11:08 AM
Black R's Avatar
25 Year Member
Are you kidding me?
I can max my gears? (toda gen II)
That's like 30 degrees!
And I'm only at like 3-4 right now in the intake...
Old Sep 14, 2001 | 11:12 AM
B18CXr's Avatar
Default Re: maximum cam advance/retard with toda b's (Black R)
your gears are on a veriner (sp) scale not the normal AEM,skunk scale no such thing as 30degrees..............I told you to max them out awhile ago for more HP!
Old Sep 14, 2001 | 11:18 AM
Black R's Avatar
25 Year Member
hrm... I still need to get a cut valve cover so I can play with them... For some reason I thought each mark = 2 degrees... I've left them at +4 degrees intake, 0 exhaust. No $ for a while to dyno and no $ for valve cover...
Did Jason ever get his B's + valvetrain + cam gears in and tuned? What is the verdict? Settings?
Old Sep 14, 2001 | 11:32 AM
B18CXr's Avatar
talk to me this weekend
Old Sep 14, 2001 | 11:44 AM
Black R's Avatar
25 Year Member
Old Sep 14, 2001 | 12:32 PM
sgT's Avatar
sgT
Just FYI, I have my spec Cs set to +5 intake and -8 exhaust.
No problems.
Old Sep 14, 2001 | 12:50 PM
Black R's Avatar
25 Year Member
Default Re: maximum cam advance/retard with toda b's (sgT)
No problems.
degrees or marks on the cam gears?
Old Sep 14, 2001 | 04:38 PM
JDM_DOHC_SiR's Avatar
New User
No problems.
DITO... These are on TODA Gears Steve..??? i.e. 1 hash line = 1 deg on the cam ....is that what you are saying ..when you mean +5 in / -8 ex..??
TIA
Old Sep 15, 2001 | 01:50 AM
Rodney's Avatar
Default Re: maximum cam advance/retard with toda b's (JDM_DOHC_SiR)
ok, thanks guys. i have to call monday to det up my dyno appointment. i should do it next week or so. i'll let you know how i make out. thanks again.
Old Sep 15, 2001 | 05:30 AM
sgT's Avatar
sgT
No. I use skunk2 gears.
When i refer to degrees, i mean CRANK degrees.
But for those of you that like marks, its +2.5 int and -4 exh.
Old Sep 15, 2001 | 06:13 AM
New User
Thaaaankkkkk y00
Edw-R
Sep 28, 2004 12:17 PM
frogsr
May 22, 2002 09:19 PM
Maxi
Nov 9, 2001 10:37 AM
Crazy DA
Sep 21, 2001 02:24 PM
