OIL RETURN flange AND OIL FEED bolt size for Garrett?
Old Nov 22, 2003 | 05:31 PM
integra-modder's Avatar
Default OIL RETURN flange AND OIL FEED bolt size for Garrett?
I remember in a post stan wrote that the oil return flange bolt size was 8mm x 1.25 and long 20mm. I got the bolts and am doing the install and they dont appear to work....
Also, I got a brass 45 degree fitting for screwing into the turbo. I think its a 1/8 fitting, but cant remember, mcmaster site order look up feature is currently down... This fitting falls into the hole...
So if you happen to know the correct size for this, let me know.
Old Nov 22, 2003 | 05:44 PM
Flamenco-T's Avatar
Default Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (integra-modder)
Mcmaster site can go down, but mine here never sleeps
the fitting to the turbo is 1/8" NPT for 5 bolts turbo and 1/4" for 4 bolts turbo
the garrett uses either 8x1.25mm or 3/8-16
stan
Old Nov 23, 2003 | 06:10 AM
Default Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (Flamenco-T)
anyone else know....?
Old Nov 23, 2003 | 06:20 AM
Optiks.'s Avatar
im pretty sure flmaenco t is right check his title
Old Nov 23, 2003 | 06:35 AM
Default Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (Optiks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optiks &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure flmaenco t is right check his title </TD></TR></TABLE>
the fittings i bought are what he said originally...and they didnt fit, so I want to get someone else to verify this..... (stan = flamenco t, look at my post again)
Old Nov 23, 2003 | 06:44 AM
Ri5e's Avatar
Some Garrett turbo's don't come with a threaded oil feed hole, so people thread them. Did you buy the turbo used?
Old Nov 23, 2003 | 09:19 AM
2K_TEG's Avatar
stan is right
Old Nov 23, 2003 | 01:50 PM
Default Re: OIL RETURN flange AND OIL FEED bolt size for Garrett? (CRV Monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRV Monster &raquo;</TD></TR><TR><TD CLASS="quote">Some Garrett turbo's don't come with a threaded oil feed hole, so people thread them. Did you buy the turbo used? </TD></TR></TABLE>
no, brand new turbo from kyle... ^^^
oil feed thread: 1/4 inch
oil return flange bolt size: 3/8 inch
Home Depot
Going there 7 times today:
Old Nov 23, 2003 | 02:11 PM
2K_TEG's Avatar
hope you don't need 8 trips, they close in 2 hours.
Kyle
Old Nov 24, 2003 | 07:44 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">
the fittings i bought are what he said originally...and they didnt fit, so I want to get someone else to verify this..... (stan = flamenco t, look at my post again)</TD></TR></TABLE>
I told you both info in the original reply...trust me you need to read my reply carefully again
stan
Old Nov 24, 2003 | 10:47 AM
mike1114's Avatar
The guy from cheapturbo told me (for the 4-bolt style) the oil drain was 10x1.25 and it was actually 3/8-16, it depends on if your garrett was made stateside or in japan.\
Oil feed, listed to flamenco.
Modified by mike1114 at 8:29 PM 11/24/2003
Old Nov 24, 2003 | 09:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">
stan
misunderstanding stan.....
I was referring to your post where you said what it was...
Old Nov 24, 2003 | 09:57 PM
Flamenco-T's Avatar
It's cool...as long as you're up and running..
stan
civic-r11
Jul 26, 2010 03:24 PM
Chee_dog
Sep 2, 2007 09:40 AM
ericstambaugh07
Apr 1, 2007 02:01 PM
acman1
Apr 23, 2003 06:05 PM
