Fuel Tank Weld-In Sumps: Whats everyone using?
Old Nov 22, 2003 | 04:12 PM
Suprdave's Avatar
Default Fuel Tank Weld-In Sumps: Whats everyone using?
I'm thinking about going with a Weld-In Sump ona Customer Car we are doing right now...Don't trust Stock Lines and a Walbro to 550whp, hahaha.
What brand is everyone using? I could fabricate one, but I would rather order something.
Suprdave
Old Nov 22, 2003 | 04:51 PM
rOby's Avatar
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (Suprdave)
comp engineering, out of summit catalog
Old Nov 22, 2003 | 04:56 PM
RenoRacing's Avatar
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (rOby)
here ya go!
http://store.summitracing.com/...D4040
Old Nov 22, 2003 | 05:04 PM
Suprdave's Avatar
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (RenoRacing)
Thats the one I was looking at...
Old Nov 22, 2003 | 05:08 PM
D-Man's Avatar
the comp engineer one that summit/jegs sells has 3/8" fittings on it,if your looking for bigger fittings http://www.wildridesracecars.com (732)751-1113 has one very similiar to comp engineering but it has 1/2" fittings ($44.95) and for $5 extra you could get it with 3/4" fittings.
Old Nov 22, 2003 | 06:06 PM
Suprdave's Avatar
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (D-Man)
Nah, only need a -8AN Feed...
Suprdave
Old Nov 22, 2003 | 10:13 PM
rtype11's Avatar
might as well just buy a fuel cell for that, comes with all the fittings and then you can delete the gas tank, save weight, and money over sumping a stock tank.
Old Nov 22, 2003 | 10:24 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">might as well just buy a fuel cell for that, comes with all the fittings and then you can delete the gas tank, save weight, and money over sumping a stock tank.</TD></TR></TABLE>
Dude, where have you been? Well we have to keep the stock tank for competition.
art
Old Nov 22, 2003 | 10:30 PM
Full-Race Geoff's Avatar
the comp eng. doesnt fit a honda tank that well. i think its a good idea to make your own from 304 sheet
Old Nov 22, 2003 | 11:04 PM
Full-Race Javier's Avatar
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (FFgeoff)
very tru...i made one for my se-r out of ss sheet. i hole sawed some holes in the tank and tig'd the sump over that area. the holes act as a baffle kinda. ill take some pics tomorrow when im at the shop
Old Nov 22, 2003 | 11:43 PM
RenoRacing's Avatar
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (Full-Race Javier)
Yeah, the hole saw is definately a must for the baffled effect. I've heard five 2" holes works nicely w/ the comp. sumps. I plan on making mine for my tank, but the comp. isn't to bad for the price and time savings.
Pics aare always nice when it comes to your guys stuff! thanks Javier!
Old Nov 23, 2003 | 01:59 AM
the comp is just odd beacuse of the way the ridges are on a honda tank. The comp is perfectly flat while the stock tank is ridged. They fit together poorly due to the shape of the comp sump, so if you make one yourself it is more likely to fit well and be strong, in the event (Rare) that you are to ever bottom it out, the custom made one is less likely to get a tear.
Old Nov 23, 2003 | 08:10 AM
Suprdave's Avatar
I'm gonna hafta pull the tank and start doing some R&D.
Old Nov 23, 2003 | 08:19 AM
tony1's Avatar
Dave, you want to run a -10 out of the sump into the pump. You don't want to go too small on the inlet of any pump. -8 for the feed out of the pump is right, but you should always go bigger on the inlet.
Old Nov 23, 2003 | 08:28 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (tony1)
Tony is right (duh), i have a -10 out the sump to the pump, and an -8 out the pump to the front of the car. I also use a -6 for my return line. HTH
Old Nov 23, 2003 | 08:37 AM
Suprdave's Avatar
Default Re: Fuel Tank Weld-In Sumps: Whats everyone using? (SIXTYdashONE)
Yea, I furgot the pump inlet was -10...I was thinking it was -8 for some reason.
V Dub Mike
Jul 19, 2010 11:58 AM
94-integra-ls
Oct 23, 2009 11:55 AM
Acidcrakker
Nov 12, 2007 06:50 PM
CiViC_SOHC
Jul 29, 2007 07:29 PM
SPOOLINmatt
Apr 13, 2006 12:29 PM
