#7 and #16 ecu code
Old Nov 22, 2003 | 01:26 PM
jester's Avatar
Default #7 and #16 ecu code
I was trying to install my blower motor and I saw my ecu throwing these codes. I did a search for them and found it to be my tps sensor and my Fuel Injectors. My question is that correct? Also, ball park range to get the problems taken care of
88 honda crx dx
Old Nov 22, 2003 | 02:35 PM
96-EJ6 B18C's Avatar
Default Re: #7 and #16 ecu code (jester)
Code 7 is the throttle position sensor.
Old Nov 22, 2003 | 03:21 PM
carrcarr's Avatar
Default Re: #7 and #16 ecu code (96-EJ6 B18C)
you are correct but i have no idea what that **** runs
Old Nov 22, 2003 | 07:36 PM
91civicEX's Avatar
Default Re: #7 and #16 ecu code (carrcarr)
is the CEL on? try reseting the ecu first
Old Nov 23, 2003 | 04:32 PM
jester's Avatar
Default Re: #7 and #16 ecu code (91civicLX)
Cel? resetting? heh How do I do that. <--- Just a newbie when it comes to some car things. Also, The car does show signs of codes. My car does idle high and my non vtec car seems like it has vtec. Heh its like vooooVOOOORMMMMM in other words it hesitates.
Old Nov 25, 2003 | 09:18 AM
If your check engine light (CEL) is on theat means that your car is throwing at least one code...you can determine which on it is by pulling your carpet back on the passenger side foot well and that will expost a plate which the ECU is under...there is a small hole in that plate and an LED that will be blinking...by counting the blinks you can figure out which code the computer is throwing...remember long blinks are "tens" and that short ones are "ones" ...i.e. one long and six shorts would be code 16 that you refered to above...to reset the ECU just pull the negitive side off the battery for about a minute then reconnect it ...that will clear all the codes frome the ecu and reset everything.
Old Nov 25, 2003 | 12:08 PM
rsbad454's Avatar
7= TPS, Throttle angle/Throttle Postion Sensor
16= Fuel injector
I agree try resetting ECU by disconnecting - cable for like a few minutes then restart.
Old Dec 1, 2003 | 05:57 AM
jester's Avatar
Default Re: #7 and #16 ecu code (rsbad454)
gotcha.. I just counted the lights. Didnt happen to see if it was long or short. Does the car throw multiple codes at once?
Old Dec 1, 2003 | 06:00 AM
Home Skillet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jester &raquo;</TD></TR><TR><TD CLASS="quote">Does the car throw multiple codes at once?
Yes, there will be a pause inbetween codes.
Old Dec 1, 2003 | 06:29 AM
rsbad454's Avatar
yes....it will blink a certain amount of times them pause, and then blink more times for the other code.
jesiaczek
Jan 26, 2012 03:31 PM
vietnamese0utlawz
Sep 19, 2006 11:38 PM
VTECth1s
Aug 9, 2006 10:10 PM
Lei Siew Long
Apr 24, 2002 09:27 AM
