Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
HPDE...stock brakes?
Old Nov 22, 2003 | 12:18 PM
HUBB's Avatar
Default HPDE...stock brakes?
want to participate in my first HPDE at Infineon Raceway next weekend. I have a 93 hatchback with a solid wheel tire combo, coilovers and front/rear strut bars. i am all stock under the hood but my main concern is that im still running my stock brake setup. i was holding out until i got my swap done. i want to run this event but i dont wat to end up in the wall.....advice needed please. Thanx
Old Nov 22, 2003 | 12:21 PM
DSC240sx's Avatar
New fluid should be enough to keep you outof the walls IMO. So long as your have PLENTY of pad material left.
Old Nov 22, 2003 | 12:28 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: HPDE...stock brakes? (HUBB)
I got one event out of stock ITR brake pads.
You'll probably need to replace them pretty soon after the event.
Old Nov 22, 2003 | 04:21 PM
D.CACO's Avatar
Default Re: (DSC240sx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSC240sx &raquo;</TD></TR><TR><TD CLASS="quote">New fluid should be enough </TD></TR></TABLE>
My highest recommendation- Ive boiled my fluid the first time out, and after 10 minutes- pedal sunk to floor. Day was done!
I never did that again!
Old Nov 22, 2003 | 05:10 PM
Mike_C's Avatar
New fluid and pads, both are a must IMO.
Old Nov 22, 2003 | 08:41 PM
Regular Series's Avatar
DEFINITELY change out your fluid and pads for something more performance oriented. My weak-*** brakes (which were new but cheap ) forced me to brake way early, and really slowed me down...in a bad way.
Old Nov 23, 2003 | 09:21 AM
HUBB's Avatar
Default Re: HPDE...stock brakes? (Regular Series)
thanx for the advice......its gonna cost like $150 for the event and then $ for pads and fluid...... im broke but wanna run....
Old Nov 23, 2003 | 09:30 AM
D.CACO's Avatar
Welcome to the dark side.....
Old Nov 23, 2003 | 11:29 AM
uncleben's Avatar
Default Re: HPDE...stock brakes? (ACRDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACRDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Welcome to the dark side.....</TD></TR></TABLE>
heh- exactly.
pads and fluid = smart choice.
i did my first event with stock pads and fluid and found that 10 minutes was about all the braking my car could handle (LS DC2) before starting to fade and turning to mush. the next trip out was with new pads and fluid, and what a difference it made.
ever since then, it's been better pads and fluid on any car of mine (or my friends) that was going to any type of track event.
Old Nov 23, 2003 | 11:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HUBB &raquo;</TD></TR><TR><TD CLASS="quote">thanx for the advice......its gonna cost like $150 for the event and then $ for pads and fluid...... im broke but wanna run.... </TD></TR></TABLE>
Heh...I found out that track fees are actually the smallest cost in a weekend. I'm in the same boat as you.
Old Nov 23, 2003 | 12:25 PM
mos's Avatar
mos
What if you have a 90 horse 1900 pound car with street tires? Even then stock pads with plenty of meat left are not acceptable?
Arrgg.
Old Nov 23, 2003 | 01:46 PM
Floyd's Avatar
Default Re: HPDE...stock brakes? (mos)
If it's your first event you probably won't be trying too many late-braking techniques. Flush the fluid with some performance stuff and you should be okay, assuming you have a lot of meat left on the stock pads. Take it easy and concentrate on the turns, not the straights.
Old Nov 24, 2003 | 04:06 AM
Bbasso's Avatar
The first time I went out with stock brakes was the last time, I killed them by the end of the HPDE and had to drive home extra careful.
Yup it sucked but now I have HPDE worthy brakes and can drive to and from there.
Pads, fluid and SS lines.
Old Nov 24, 2003 | 06:34 AM
GSpeedR's Avatar
Default Re: (Bbasso)
i would also invest in (at least) a set of front pads for the track. My Axxis Ultimates survived 2 track days without fade but I would suggest something more aggressive. Cobalt and Carbotech both have "entry level" race pads (not too aggressive for your rotors). Flush your fluid and you're good to go.
Old Nov 24, 2003 | 07:29 AM
mos's Avatar
mos
Default Re: (GSpeedR)
Welp I went out and bought raybestos ceramics for the front and some GTLMA...
Thanks for the replies, even though this isnt my thread!
Old Nov 25, 2003 | 09:15 AM
HUBB's Avatar
Default Re: (mos)
yeah thanx for the advice and replies......i think after all that im gonna have to pass on this event dur to $.......next year then
Old Nov 25, 2003 | 09:28 AM
Mike_C's Avatar
that's too bad, did you spin your car on a freeway ramp or something?
you know if you didn't replace your hatch with a cf one you could probably afford the event.
reference: https://honda-tech.com/zerothread?id=685641
Old Nov 25, 2003 | 09:32 AM
HUBB's Avatar
Default Re: (JMU1337)
yup....i only have liability coverage so i have to fix it with my $ .....i could leave it...not hurtin anything but i am a neat freak so im fixin it...need bumper, hatch, taillight, and quarter panal straightened....its gonna cost me....also with the rain my quarter panal is rusting where the paint chipped any idea how much all this will cost?
Old Nov 25, 2003 | 09:37 AM
baonest1's Avatar
Default Re: (HUBB)
i ran stock pads, lines, and fluid. basically stock brake everything. and yah, it did suck. especially when you have a fast car, but have to brake EARLY as hail
Old Nov 25, 2003 | 11:30 AM
granracing's Avatar
It also really depends on the track you would be driving on. For example, New Hampshire International Speedway - hard on brakes. Most other tracks around you wouldn't have a problem. I have done many HPDEs with stock pads. Like others said, make sure the fluid is fresh.
During my last race weekend, I had ran out of pads and had to race the second race on stock pads. At the end of the race, it got a bit tough but it got me out there. You also have to remember it is a HPDE not a race. If they start to heat up a lot, you can simply slow down or come in and wait till the next session.
My father actually did his first HPDE with my car. I actually took off the race pads and put on street pads. Being a novice, he wasn't thresh hold breaking, and it is actually easier to use. It can be quite easy to lock up the wheels with the race pads when starting out...
Old Nov 25, 2003 | 12:52 PM
Outsane's Avatar
Default Re: (granracing)
Honestly... the more you worry about money...the less your at the track..
In my experience..
Old Nov 25, 2003 | 01:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">For example, New Hampshire International Speedway - hard on brakes.</TD></TR></TABLE>
Heh...my only HPDE so far was on NHIS. I scrubbed off about half of my front brakes there.
Are you a member of COMSCC?
Old Nov 25, 2003 | 01:42 PM
HUBB's Avatar
Default Re: (Regular Series)
no
Old Nov 25, 2003 | 02:25 PM
Default Re: (HUBB)
I was asking granracing.
Old Nov 26, 2003 | 11:26 AM
granracing's Avatar
No I am not. I primarily do SCCA and EMRA. I also have instructed with SCDA and NASA.
Any plans to make it to Lime Rock this year? I really love that track! (It is much easier on your car / brakes)
