SRR rear tie bar with ITR sway???
Old Nov 22, 2003 | 12:10 PM
Carpediem291's Avatar
Default SRR rear tie bar with ITR sway???
Do you know if this combination will work on 92-95 eg hb?? Just want to know if this will work or not. thanks
Old Nov 22, 2003 | 12:12 PM
GReddy SI's Avatar
Default Re: SRR rear tie bar with ITR sway??? (eEKEGg)
bump i would like to know also
SkyeC's Avatar
Boba Connoisseur
25 Year Member
The guys at Exospeed say it will.
Old Nov 22, 2003 | 01:06 PM
Default Re: SRR rear tie bar with ITR sway??? (SkyeC)
I am getting an ITR rear sway with BSQ kit. I looked at where my rear tie bar is located and there is no place to install the BSQ kit to the subframe.
Old Nov 22, 2003 | 01:37 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
In theory you can use the SRR rear tie bar as a subframe brace.
Not familiar with how the BSQ kit works.
Old Nov 22, 2003 | 01:58 PM
does that mean i don't need the bsq kit (reinforcement kit) to install the itr sway bar if I already have the srr reat tie bar
Old Nov 22, 2003 | 03:46 PM
SASIR2's Avatar
No, u don't need the BSQ kit, the SRR lower tie bar takes the place of the BSQ kit.
Looks better too!
Old Nov 22, 2003 | 04:19 PM
Default Re: SRR rear tie bar with ITR sway??? (SASIR2)
would it be strong enough? It's not going to rip out easily?
Old Nov 22, 2003 | 06:44 PM
eg6beater's Avatar
i've had my srr rear away with just a gsr rear sway...gave the car hell in the twisties and bumps but no sign of rippage or bending.... looks god too!
Old Nov 24, 2003 | 07:12 AM
SASIR2's Avatar
Default Re: SRR rear tie bar with ITR sway??? (eg6beater)
Yeah, it provides good support over a pretty large area. Check out http://perpetualconcepts.com for more info.
Old Nov 25, 2003 | 04:14 PM
i'm getting itr sway bar and it's thicker 22mm. I think GSR sway is 19mm. Don't you think reinforcement kit is still necessary?
Old Nov 25, 2003 | 04:25 PM
ill phil's Avatar
GSR rear sway is only 14mm by the way. And yes a reinforcement kit is definitely suggested for the ITR rear sway. So basically you are just asking if you can use the SRR piece as the reinforcement? It would be like running something similar to the Comptech set-up. If you mounted the rear sway to the SRR piece then there wouldn't be a need for Beaks/BSQ since those mount to the actual subframe.
Old Nov 25, 2003 | 05:15 PM
Default Re: SRR rear tie bar with ITR sway??? (ill phil)
thanks for the info
Takumi Fujiwara
Feb 22, 2005 06:50 PM
jeremy.
Dec 15, 2003 08:49 AM
IntEGNYC
Jan 10, 2003 10:38 AM
chethewitt
Nov 5, 2002 12:16 AM
Red98GSR
Jun 16, 2001 07:34 AM
